How to change brushes on Bosch w/machine motor
I have accessed the motor but can't work out how to releases the worn brushes in order to replace them
  • 311 Answers
What model? Never have seen a motor with brushes on their stuff. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
I have a Bosch WFL 1200 front load washing machine. I need to replace the brushes on the motor. This model only has an "oval" shaped panel at the back. The side and back panels are all one piece and c
ALWAYS disconnect electrics....You need to access the motor from the bottom of it is a pig to work on if you try to replace the bushes whilst in situ...what I do is empty the machines residual water from drain tube bottom front then remove back.... undo belt .... Then lean the machine at 45degrees to one side and undo the two retaining bolts on the pulley side .the whole motor will slide toward rear of machine but uncouple the electrics block first then remove motor.the brushes are spring loaded and the brass clip slides one way to release?there are plenty of YouTube tutorials on bosch washing machines that show brush replacement.good luck.
Jan 29, 2015 | Bosch Washing Machines
Bosch Washer WFK2401UC/01 Does not spin. Replaced Power cir. Bd. Turned on started right up. completed cycle. Went to wash this morning Drum will not spin
Sometimes the brushes on the motor get worn and they cause motor to act intermittently. I changed my brushes and this corrected the problem of not washing or spinning.
Dec 11, 2014 | Bosch Washing Machines
Bosch logixx f:43code E-Nr. WAS32741AU/20 FD 8901 200134
F:43 meant motor error. We have electronics engineers as father-in-law (lucky). We checked motor - all good. Replaced worn brushes (cheap replacement). Still f:43 flashing after reset. Replaced PCB (Power Control board) with one that we ordered from Bosch factory and installed. Working like new. New brushes make light buzz which is normal.
Oct 11, 2013 | Washing Machines
Hi i just want to check to see if belt is ok, but dont know where to look, i have a drum wont turn
Its probably your motor carbon brushes. If the machine electricals work OK and it pumps water in and out then the carbon brushes have just worn out on the motor. I had the same problem with my Bosch front loader. Easy fix and you can get help visually on youtube. If you are looking for the belt to see if it has come off, undo the screws that hold the plate on the back of the washing machine to access and sight the belt. Also this will give you access to the motor if you need to change the motor carbon brushes. Hope this helps Sue
Aug 09, 2011 | Bosch Washing Machines
I have removed the motor from the washing machine but cannot see how to release the brushes. Have changed brushes on other machines before but struggling a little here
Hi from retired Englishman in SW France @ 15:55 Sun afternoon.
Our Bosch behaved intermittently then would not run at all JUST before xmas and visitors!. I removed the motor and could see that the brushes were worn. I actually could not see how they could easily be removed- really solid bit of kit.
Went on a web site (cannot remember which one) and the advice was that if you (are able to) change the brushes they will not last for very long- a few months was the experience. As you probably are aware they do not necessarily bed in very well, that is unless you go to the extent of sorting the commutator out first.
Our Bosch is 15-20 years old- good machine and our new motor should last another 15-20 (which is more than we probably will!). Admittedly it did cost £250 but VERY easy to change-took minutes- and I changed the belt at the same time.
So- it might be false economy ;-0(
Good luck,
John C
Jan 30, 2011 | Bosch Classixx WFO 2466 Front Load Washer
Drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Nov 08, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx6 1400 express
Possibly worn brushes in motor.
Remove rear panel, remove belt, remove motor connector plug, inscrew 2 screws that secure the motor.
Lever motor back with a screwdriver, keeping hold of it as you do.
You will see the brushes at the terminal end of the motor.
If they are less than 4-5mm, they need to be replaced.
Refit motor and belt and motor plug. Test on spin
Plz rate my solution.
Jan 04, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Motor not running.
if your brushes are only 1/4" long, I would replace them. The symptoms sounds like worn brushes.
Aug 26, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
My bosch washing machine wfo2865 exxcel is not spinning. Every thing else works. The engineer said it could be the brushes. How do I take the motor out to replace the brushes
remove back panel.remove motor wiring undo two bolts in front. remove belt. motor will pull out.
my experience of these is that often the commutator is damaged hence brushes worn
Aug 07, 2008 | Bosch Washing Machines
Bosch WFL 2060 front load
bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
Dec 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
