Question about Intel D945GNT Motherboard
Cannot boot the system.
My pc cannot boot. it makes a 2 siren/beep sound when i switch on the power. after the siren it just shuts down.
i wanted to clean my hardware, so i took apart all the hardware there is. psu, graphic card, hd, cdrom, all of it. except the cpu. when i put them on back, it wont switch on. it just make 2 siren sound then switch off.
do you have any solution to this problem.
  • Anonymous Nov 29, 2008
    my pc cannot boot. it makes a 2 siren/beep sound when i switch on the power. after the siren it just shuts down.
    Guru:
  • 859 Answers
Your RAM memory modules are failing the power on self test. That is what two beeps or signal alerts means.
You may have these inserted your memory sticks in the wrong slots.
Often slots are color coded. Insert them in two of the same color. Try again. If no success, switch to another set of slots in another color.
If that too fails, insert only one memory stick at a time into bank 1 labeled DIMM 0. This is binary and the numbers start with 0, not 1.
Insert a single stick in bank 0, one at a time until the PC boots.
If it boots on each stick by itself but not together, then you have a bad chip on one of the memory sticks.
Most memory sticks have a decent warranty but there are exceptions.
You may also have a stick that is not seated correctly. The method is to push the stick into the slot evenly with two thumbs each on the ends of the memory stick until the locking tab seats on its own accord. You should not have to force the locking tab into position.
Ask any questions using the Comment Box below.
Thanks,
Worldvet
Posted on Nov 29, 2008
    Novelist:
  • 167 Answers
When you put the RAM back into the computer did you return them to their original bank? Dual Channel DDR RAM is particular about being in shared bank with the other RAM module; that's why the color code the RAM Sockets in some motherboard designs so you don't them mixed up. Moreover, is the CPU fan spinning for the short time it is powered up?
Posted on Nov 27, 2008
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
It makes few siren sounds, and then display "boot system failure"
Never heard of a HDD making siren sounds but if you mean a series of beeps from your PC then they are codes which indicate the problem.
See here for how to interpret them.
Sep 02, 2010 | Western Digital Caviar WD450AA 45 GB...
Microstar ms-6390 will not boot. The fan starts then stops as it begins to beep. The beep sounds like a siren or something high tone low tone over and over. It only stops when power is disconnected or...
The problem is-- your motherboard is not able to detect the system RAM.It's the sound you hear as siren.Open the PC and slowly remove the RAM from motherboard and clean the slot and the RAM legs with a clean white paper and place it again.It will solve your problem instantly if the RAM is not burn out.check the other RAM slot by placing the RAM again if the above procedure does not work.
If the problem still persists,replace the RAM.
Dec 14, 2009 | Compaq Presario 5000 PC Desktop
Blank screen, not boot screen.
Not all of this applies to you but the links for the beep codes may well be of use to you.
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Sep 19, 2009 | Compaq Presario R3000 Notebook
Computer when turned on will not boot and makes a long beep continuously and then makes like a siren sound
The long beeps probably mean a problem with RAM. So try replacing it. Check whether the CPU Cooler (the fan on top of the processor) is working. If the fan is not working, the processor gets hot, and a siren sound is emitted. Also check whether power unit fan (at the back) is working. If RAMs are replaced and you still get the beeps, the problem may be with the VGA. (The beep sounds help to identify the problem, but the sounds differ with different BIOS models).
Jul 30, 2009 | Computers & Internet
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Computer shuts down
check temperature of your pc, if it goes then use proper system fan and also clean your system from dusting.
Oct 17, 2007 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Intel D945GNT Motherboard Logo
127 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
