Sharp Aquos LC-45GD6U 45 in. LCD HDTV Logo
Posted on Feb 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot change the channels on my direct TV receiver when tv is
I have a Sharp Aquos 45". Lately I cannot change the channels on my direct TV receiver. If I turn the TV OFF teh infrared sensor on the receiver works fine. I place a different TV on the receiver and everything works fine. It is just this TV. I have had it for 2 years and problem just started
greg ferreira
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 97 Answers
  • Posted on Feb 08, 2018
greg ferreira
Expert
Level 2:
New Friend:
Greenhorn:
Answers
97
Questions
0
Helped
26581
Points
305
Have you tried a factory reset on the TV.Also try unplugging the tv wait about 20 seconds and then plug it back in.Last check the trouble shooting in the tv manual
5 Related Answers
Anonymous
  • Posted on Mar 19, 2008
SOURCE: sharp aquos fault
Thanks to this forum, I was able to confidently contact Sharp and get my TV fixed.
My 32" LCD had the same problem (sound but no picture) and was out of warranty, however I phoned Sharp UK and suggested that it was a manufacturing defect rather than component failure and should be repaired free of charge - which they did!!
Anonymous
  • Posted on Oct 19, 2008
SOURCE: 37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
Well I tried a cable amplifier & that solved my problem. I now get all HD channels without an HD cable box.
Anonymous
  • Posted on Dec 18, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Anonymous
  • Posted on Feb 10, 2009
SOURCE: Freeview channels (DTV) on a Sharp Aquos TV
I have a Sharp Aquos 26-D44E. The factory preset PIN on this one is 1234.
Anonymous
  • Posted on Mar 26, 2009
SOURCE: Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
1helpful
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
The audio on my LC-45GD6U goes in and out (mostly
if its fine on other channels i would not suspect the tv
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
2helpful
I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
22helpful
6answers
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
2helpful
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
2answers
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
