Question about AudioBahn AVM372DVD 7 in. Car Monitor
Will not load a dvd
When putting in a dvd it will just eject it, tryed others dvd and they do not work. Before it got to this point the dvd would just spin and the sceen would say loading, but nothing would come on. Got any thoughts? Thank you for your time Bill Kolenda
    Scholar:
  • 72 Answers
Dirty laser assembly or Just a bad laser. When you stick the disc in if the laser does not see it at all it will eject the disk out right away. And what you described it has been doing this for a while. I do not know if a lens cleaner will work for you. Generally they have to load to clean. Taking apart and cleaning with Rubbing Alcahol and a Q-tip. might be your answer but this sometimes can be difficult,because generally the mechanism is in the way and restricts access the the laser. If you are good at repairs try cleaning the laser if not maybe take to a shop and get an estimate.
Posted on Jan 12, 2007
VCR EJECT FAILURE
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
Jan 28, 2008 | Goldstar GBV241 DVD Player/VCR
Dvd only for computer laptop put into benq dvd player wont open?
method 1
there will be a small tiny hole in the front panel below cd tray,insert a paperclip (don't use screw drivers) just flush it in smoothly and press eject button ,it will eject
method 2:
restart your system try to eject before the os loads,
method 3:
go to device manager find your device there and uninstall the driver and reinstall it
i hope that any of the above method will work
regards,
cseian
Jun 14, 2010 | BenQ DE350 DVD recorder/HDD recorder
When a DVD is inserted, the screen indicates its loading, but it never goes beyond that point. The only other info that might be relevant is that initially the eject mechanism wouldn't function, so the...
there might be some compatibility problem . some times the dvd is not recognised by many players. not ot panic , just try ur dvd on some laptop to check whether there is problem in dvd or the system
Aug 11, 2009 | Soundstream VCM-81D 8in Overhead Monitor...
Dvd player not working on 06 Honda Odyssey
The Honda dealer just wanted to replace my entertainment center without even troubleshooting and I wasn't convinced that it was "broken" so I found the FIXYA website and saw that others had the same problem and I followed their instructions and it now works fine. I am going to call the Honda dealer to complain because they should have known this.
We simply pulled the fuse out and put it back in and then reset the radio code!
Mar 18, 2009 | 2006 Honda Odyssey
Samsung dvd-r130
you advertise on web sit let our experts solve your problem for free then you want me to pay im out of work at 60yrs old or i would gladly pay to hep me fix the problem
all the best and thanks
Jan 14, 2009 | Samsung DVD-R130 DVD Recorder
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Technical support needed can't get player to eject disc
Huncha,
I had the same problem today.  I got a screwdriver and opened the case from the back.  It was simple, just 3 black screws.  Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd.  I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out.  Then I put the cover back on and put the screws back in.  Works fine now.  I hope this helps you.  I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself.  Good luck.
Dec 27, 2007 | Samsung DVD-P241 DVD Player
Can not load or Eject DVD
Be sure NOT to load any CD+ -R,CD+-RW or DVD+-R,DVD+-RW to this unit.
Try to load up a standard CD see if there is audio first. If so,try a good(not scratches) dvd movie.If you have tried both and still not working.You need this unit to be repair or buy a new one!
Joe
Apr 18, 2007 | Sony DAV-C990 System
AudioBahn AVM372DVD 7 in. Car Monitor Logo
123 people viewed this question
Top AudioBahn Car Audio & Video Experts
Mike Duncan
Mike Duncan
matthew walsh
Level 1 Expert
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
