When I play a DVD it works, the picture plays well, however the sound makes a very loud ticking sound while it plays. Any advice on how to repair this?
SOURCE: cant play a dvd on laptop hp pavilion dv4000
check ur software that plays ur disks e.g.media player when first installed needs dvd media to be enabled.sounds to me that software is not enabled or codecs are not installed.if it plays cd's ok there is nothing wrong with ur drive whatsoever its a software issue.theres dvd player software at the hp site free to download includes all codecs and plays most media called windvd.
make sure you got the right drivers for your unit... specially if your using operating systems that exactly supports that drivers you 've loaded with...
SOURCE: CDR/DVD R Drive Repair
First of all, I would recommend you to copy the movies or audio files to the Hard Drive and play from there as it is not totally recommended to play audio or video files from the DVD Drives directly which may reduce its life span.
For DVD Videos, you need to copy the Video_Ts folder which containt the video files.
Sort out the files according to file types and files with .Vob are the video files which can be played.
However, if you are not comfirtable with the above instructions, try the steps listed below which I use to resolve this kind of issues :
Step 1:
1. Click Start.
2. Right-click My Computer (My Computer is on the Desktop for versions of Windows prior to Windows XP).
3. Click Properties.
4. Click the Hardware tab.
5. Click the Device Manager button (Device Manager is a tab in versions of Windows prior to Windows XP).
6. Click the plus sign (+) to the left of IDE ATA/ATAPI controllers to expand this list.
7. Right-click Secondary IDE Channel.
8. Click Uninstall (Click Delete for versions of Windows prior to Windows XP).
9. Restart the computer.
10. Repeat steps 1-7.
11. Click Properties.
12. Click the Advanced Settings tab.
Verify that the transfer modes for both Device 0 and Device 1 are set to DMA if available.
13. Click OK and try playing a DVD.
i) The current transfer mode should read some thing like "Multi Word DMA Mode 2" or "Ultra DMA Mode 5" under Advanced Settings tab after this.
ii) The above procedure applies only to certain model notebooks. If the Secondary IDE is not listed, then this step will not help resolve the issue.
Step 2:
DMA setting will not stay enabled after rebooting (OR) switches back to PIO from DMA during startup:
IN this case, Please download/install of Notebooks Windows XP Registry Patch to Reset DVD Mode from PIO to DMA from:
ftp://ftp.hp.com/pub/softpaq/sp20501-21000/SP20531.exe
Step 3:
You may experience stutter, echo, or distorted sound if the hardware acceleration is not set correctly. To experience good audio quality, adjust the hardware acceleration slider for speaker in the Device Manger by following these steps:
1. Click Start and then Control Panel.
2. Click Sounds and Audio Devices.
3. Under Speaker settings, click Advanced.
4. Click the Performance tab.
5. Change the Hardware Acceleration slider's position.
NOTE: The slider can be positioned from "none" to "full" depending on the usage.
6. Click Apply and OK.
Repeat steps 5 & 6 till you get optimum audio performance.
Step 4 :
BIOS Reset
1. Restart the notebook.
2. Tap the F10 key as soon as the HP logo appears.
3. Using the arrow keys, navigate to Exit menu and select Get defaults values.
4. Navigate to Exit menu and select Save Changes and Exit.
Even this steps look lengthy, they should resolve the issues.
SOURCE: Dvd plays initially and then stops
It could be the drivers for CD/DVD.
The best way to troubleshoot this is right click on computer, select manage. A new window will pop up, in that list select device manager.
Look in the list for CD/DVD drives and click on the + sign next to it, when the tree opens right click on the CD/DVD drive and select uninstall, then restart the PC.
This method will hard reset the system and force windows to load the default drivers for the CD/DVD upon restart. Hopefully this should resolve your problem.
If not please post back.
Good luck
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
hope this helps
