Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Not allowing second laptop to connect
I have 2 laptops. I hooked up my laptop first with the router and it worked just fine. Then i went to hook up my sons and laptop and it wont let him onto the internet. it says windows was unable to find certificate to log you on to the network Belkin_N_Wireless_ED22FF. can you please help me?
  • lilsue1962 Nov 28, 2008
    Thank you, i will try this. Happy Thanksgiving.
  • Jannette Amandy May 11, 2010
    There is a certain certifacate or key enabled in your router that must be configured in the second laptop. You can check for this network key from the your router's user interface.
    Hope this helps!
    Scholar:
  • 132 Answers
Happy Thanksgiving, too. Please update me about this so I can assist you more.
Posted on Nov 28, 2008
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Keep getting kicked off
when sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
May 31, 2010 | Belkin N Wireless Router wireless router
We set up the router without a security password but when I try to connect with a second computer it keeps asking for security code. The first laptop we hooked up works fine...the second laptop we cannot...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 08, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
Screen went black
sounds like your monitor is shot or one of the connections in the back hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
Connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Jan 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
171 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
