Question about Microsoft Xbox 360 Console
Xbox 360 has no picture
My xbox 360 has a sound but the video has no picture
  • TreE18 Nov 27, 2008
    i did everything but the pic wont come in it was workin fine at first an wen i turned it bac on the pic wouldnt come in at all
  • TreE18 Nov 28, 2008
    the ppl was like that they got 2 repair it 4 100 bucks an if i can do it myself im not payn them its jus a black screen w/ sound
  • 96 Answers
If you are using the HD output on the xobx then start with the SD one's first and then go into your consoles settings and change them to the standard you will be using. also if in america make sure the NTSC/interlacedmode is selected if that is an option.
Posted on Nov 27, 2008
  • Edward easley
    Edward easley Nov 28, 2008
    Ooooo. Sounds as if you got one of the lemons. there are a lot of them out there. before you go wasting gas, the 360 usually indicates that it's video connection isn't proper by having a funny colored light on the power button ring. try wiggling it.
No picture no sound
switch to a different video on the back of the tv
Jul 16, 2010 | Microsoft Xbox 360 Console
My xbox 360 won't sow the picture but i have sound
try it in another tv with av cable
if u are using hdmi cable try changing the existing cable
if it works in another tv , go changing the setting in the displaysettings and video settiing
Mar 05, 2010 | Microsoft Xbox 360 Console
Have got no picture on my tv xbox 360 is loading
you probably have a broken video or hdmi cable. somtimes the cables can even break at the connections or under the plastic coating, making the video going from your xbox to your tv not work.
Sep 14, 2009 | Microsoft Xbox 360 Console
My Xbox 360 will not show a picture you can hear the sound but there is no picture.
1) make sure the video cable is firmly inserted into the back of your xbox 360. Sometimes a loose connection will produce this result.
2) Check the end to your television set and make sure it is in correctly. Is this HDMI ??
3) Cycle the inputs on your tv until it gets back to your xbox 360 and see if the picture appears.
4) If you have this hooked up via HDMI, connect it through another method and go into the video settings in your xbox 360 dashboard and set them to auto detect.
Let me know if this helps.
Jul 28, 2009 | Microsoft Xbox 360 Console
My xbox 360 has sound but no picture. I tried the overheating with a towel and it worked for about 10 minutes. Now I have sound but no picture again.
It needs to be fixed, the right way.
If it's still under warranty, microsoft.
If not most shops and dudes on craigslist do it for $40.
Or you can go diy for about $10-15
Jun 19, 2009 | Microsoft Xbox 360 Console
I have sound on my xbox 360 but no picture
I've seen this symptom before. Try removing the external hard-drive and see if the picture comes back. Another cause could be the video resolution setting. If the Xbox video resolution is set higher than your TV can display you will get a blank picture with sound. Try reducing the Xbox resolution if the hard-drive trick doesn't work.
Jun 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Xbox 360 plays for a few minutes and then the screen goes black with no sound or picture.
your graphics processor IC chip needs its solder joints reflowing, and the heatsink re securing.
This will solve the problem.
Regards
FixMyConsole
May 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 no picture
do you get sound but no picture it is the red ring of death
Apr 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 has sound but no picture
check the video cable that connects to the T.V to see if it is damaged, if it is get a new one.
Jun 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
