Question about HP Deskjet F340 All-In-One Printer
Printer is offline.
Yesterday, while printing, I accidentally turned the printer off. Today, it will not print. I can copy, and scan. I checked the printer folder and it says it is offline. I clicked on the "use online" line and it still is offline. My daughter-in-law, who is my "computer geek" is unavailable right now, and I really need this printer to work. Help, please.
    Problem Solver:
  • 12 Answers
Remove the usb cable & refit after 10 seconds..
Posted on Jun 26, 2009
  • 3 Answers
Hi iam kishan from india do one thing if u have a driver cd of your priner disconnect printer and go to control panel clik on add/remove program remove all driver oand sofftware of your printer and restart ypur pc and after restarting insert cd in install software of your printer do no connect printer untill computer want or connect after finnish i
Posted on Jan 20, 2007
Printer is offline
Check your Laptop to see if it is in Airplane mode. If so turn off this mode. Turn off I pad when using laptop to printer. Might have to go into control scroll down to devices click on printer follow instructions to rest to default printer. Might have to use the right click button.
Feb 01, 2015 | HP Photosmart 5510 Wireless e-All-in-One...
Sharp MX4100 maintenance code vk
Check out this little walkthrough I have put together. Adjusting the printer port settings on your computer should take care of it. Sharp Printer Offline Solution
Feb 20, 2014 | Sharp "MX-4100N Copier, Printer, Scanner...
I have a mac book and have always successfully been able to print wireless. The scanner however would never work. Yesterday I needed to scan a document so i plugged the printer into my mac and scanned...
Check the settings on the printer to see if you have to switch from scanning to printing, also if you have the original setup disk for the printer just run it again and that will solve the problem.
Mar 19, 2011 | Computers & Internet
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Offline message
if the computer says printer off line then they are not comunicating try to reload driver
Jul 28, 2010 | HP Office Equipment & Supplies
Printer is online, but status is offline
Hi, make sure if the pdf you can't print is restricted by owner password which prevents you from copying, editing and printing pdf files. User a pdf password remover to remove pdf password. AnyBizSoft has a product like this.
Jan 15, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Computer says Orinter is Offline but is connected. Has the Fax button highlighted. Only have Copy, Fax, Scan, Memory Card to select from, which one should be highlighted for printing from connected PC
In order to print from PC you should choose COPY function. To check the connection between PC and your printer perform these steps:
  • Right click on printer driver name (Canon PIXMA MX 850 in this case)
  • Choose Properties
  • Click on Maintenance tab
  • Click View Printer Status: the status should ONLINE in order to print or scan
If still Offline,please recheck USB cable,reinstal it,or compare with another cable.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MX850 Multifunction Printer
Printer not responding
I had the same problem after I accidentally pulled the power cord out of the printer - it turned out to be the firewall on my PC, when the printer reconnected to the wireless network it got a new IP address and the firewall was blocking incoming messages from it.
Jun 13, 2009 | Canon PIXMA MP620 All-In-One InkJet...
223 people viewed this question
Clive
Clive
