Question about JVC GR-PD1 Mini DV Digital Camcorder
Cannot Capture video from JVC GR-PD1 using Premiere Pro CS3
Hi,I cannot Capture video from JVC GR-PD1 using Premiere Pro CS3. I *THINK* (I didn't to the recording myself) the video was recorded with the camera set to PS50 mode: "PS50: Allows you to record on a tape in MPEG2 format (576p)." Premiere recognises the model of the camera, and I am able to set up device control, but no image is fed through. I've tried with various project settings, no luck. I assume if footage had been recorded in regular DV mode there wouldn't be a problem.
I don't have the software or Driver cd that came with the cam. And I'm on an iMac. I would have thought Premiere Pro CS3 would handle this without a problem.
  • perplexi Nov 27, 2008
    to add, I saw this post:
    http://www.fixya.com/support/t188497-cap...
    ...."I have a similar problem, i - by mistake - shot some footage in ps 50
    mode. Now i can capture it in my mac by playing it analog, and than
    capture it."
    Does this mean I have to capture the material analogue? Surely not In this day and age?? :)
    Me again. I managed to capture the video using the following project settings:
    Sony XDCAM HD/Ex (SP) 1080i
    Capture Settings: HDV
    Cam set to PS50 and MPEG2.
    However captured files ONLY playback in VLC player (so far as I can tell.) I can import into Premiere for editing, but when exporting, either returns an error or has incorrect dimensions, even with same 16:9 settings selected. weird. will look again tomorrow.
Capture HM-DH5U Video into CS4 Premiere Pro
Personaly I would use either windows movie maker, nero, or the applicatiom that came with the camera just to get it to the PC.
From there It would be easier to edit etc.
Aug 14, 2009 | JVC HM-DH5U 35-Hours Video Recorder
Adobe Premiere Pro Cs3 problem
the video format is not support this software . so you get the runtime error!
Apr 04, 2009 | Adobe Premiere Pro CS3 Full Version for PC...
JVC GR-D23E download video
here is a usb driver for JVC cameras from GR-D20 to GR-D70 for windows XP:
http://odsiebie.com/pokaz/1654699---3329.html it's on free polish server
Nov 28, 2008 | JVC GR-D23E Mini DV Digital Camcorder
JVC GR-D370 not capturing with Adobe Premiere
you will need the firmware and drivers from JVC on your dell then it will work perfectly. hope this helps Jerry
p.s. you can download from JVC everthing you will need for your computer.
Sep 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Vista
hi dear
just using card fire wire
and transfer it with software like: , pinacle, Ulead Video Editor, adobe premiere ...sony vegas ...cyberlink power director.and many moore
oke
cropp
Mar 21, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Jvc camcorder GR D50EK
hi dear
you not ned a driver for this, you just need a fire wire card ...it' better than USB cable
after that, using pinacle, Ulead Video editor or adobe premiere ....softwaare to transfer that
ok
cropp
Feb 25, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Jvc gr-d50aa driver
http://uk.jvc-service.net/public/download.cfm/prodsoft/Streaming_XP.zip?model=GR-D50&size=256396
USB driver
Oct 06, 2007 | JVC GR-D50 Mini DV Digital Camcorder
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
Check out: http://jvcgr-pd1.blogspot.com/2005/07/dealing-with-pd1s-format-m2t-or-mpeg-2.html Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
JVC GR-PD1 Mini DV Digital Camcorder Logo
282 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
