Question about KLH CDR2000 2-Disc CD Recorder
CD-R does not read disks anymore
All disks are invalid. Is there a way to replace the CD-R drive within the unit?
  • Anonymous Dec 05, 2007
    HAD THE SAME PROBLEM, I WAS TOLD NOT TO USE SONY, MEMOREX CDS; TDK ARE IDEAL.
  • Gamered Feb 22, 2008
    We've used Verbatim blank cd's to audio record for years, now our unit show's they are not being reconized. nothing changed I'm not sure why we are getting this error message. We can use Memoriex Audio bland cd's.
Am/fm srereo vertical cd player wall mount. push open latch will not hold cd door closed.
Posted on Sep 28, 2009
I recently resolved CD-R recognition problems with the KLH CDR2000. It's absolutely imperative that you utilize CD-Rs bearing the logo "COMPACT DISC DIGITAL AUDIO RECORDABLE". These specific CD-Rs are designed for digital music recording with the KLH CDR2000 and other simular products. I have a Marantz CD20 that has the same CD-R requirement. I purchased a Memorex 50-pack from Best Buy for approximately $20.00 plus tax. The recordings with the Memorex CD-Rs are immpressive for the KLH CDR2000 given the obvious flaws in design. Again, when searching for compatible disc for the KLH CDR2000 look for the words "DIGITAL AUDIO" within the "COMPACT DISC RECORDABLE" logo.
Posted on Dec 29, 2007
Cd drive xhnge
On the front of the CD rom there is a small pin-size hole, carefully put a drawing pin into the hole and it will open the CD drive manually, if it doesn't read disks anymore consider replacing your CD drive
Apr 17, 2014 | MSI Computers & Internet
Invalid system disk
The computer TRIED and FAILED to boot from the hard-disk, and now is expecting you to insert a "bootable" CD-ROM into the optical drive. Replace the "dead" hard-disk.
Dec 01, 2013 | Compaq Computers & Internet
My cd drive wont open or read disks anymore what can i do to fix this?
If its not reading your CD any longer, you will need a new CD Rom drive. If it not opening either, the power to it needs replaced which is the whole unit.
Dec 31, 2010 | Acer Aspire 4520-5582 Notebook
Ibm deskstar model dtla-307015 invalid system
For some reason, the computer isn't able to read the hard drive and Windows isn't being found. If this computer has a floppy disk drive, make sure there's no disk in it. (Some people still use floppies, and the normal setting for systems with floppy drives is to try booting from that drive first. You may have a disk in it that isn't bootable.) Other possible causes are hard drive failure, a virus or other malware program has damaged the drives boot sector, or a motherboard problem. The most likely cause would be the hard drive; as a mechanical device they are more prone to fail than other parts.
Mar 08, 2010 | IBM NetVista M42 PC Desktop
CD-RW Station can't read disks anymore
The easiest thing to do is to update the firmware on the drive. If that doesn't work, check to see if the drive is getting adequate power, which can be caused by new hardware being installed that is taking up more power than the power box can give.
Clean the plugs and ribbon leading to the computer with a quick burst of compressed air.
If that still doesn't work, the laser may be mis-alligned, or borken, and is much easier to replace the whole drive. (CD-RW burners are insane cheap with DVD-RW burner drives being out for a long time, and Blu-Ray burners just around the corner)
Dec 17, 2008 | EXP Computer EXP CD-RW Station CRW 2400U...
IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Wont start up
Sounds like you have a CD or DVD in your CD or DVD drive, or if you have a floppy drive, a floppy in it.
If these are empty, Put in your recovery CD and see if it reads that.
Jul 17, 2008 | Acer TravelMate 212T Notebook
Invalid system disk--dell latitude 6600
A few possibilties on this:
1. Check to make sure both the floppy and CD drive do not have any media in it.
2. This is a used computer and its hard drive was erased to protect old info from being seen. If this is true, you will need to get an operating cd disk (ie. windows XP, windows vista, etc) and boot up from that drive. Follow the instructions from there.
3. Hard drive has failed and needs to be replaced.
Apr 27, 2008 | Computers & Internet
DVD Drive not working properly
Try cleaning the drive with a cleaning disc (purchasbale at most electronics stores like Best Buy or Circuit City). If that doesn't get it up and running, it'll need to be replaced.
Jan 29, 2008 | HP Pavilion dv6000z Notebook
KLH CDR2000 2-Disc CD Recorder Logo
334 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
