Question about Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater
Pilot will stay lit but will go out when unit is turned to low
The pilot light will start just fine and stay running. When heater is turned to low most of the time the unit will go out including the pilot. Have changed the regulator and have a new 5 gal gas bottle because seems the unit is getting no gas. Hooked up an old bathroom heater to line and workds great so tank and regulator seem to be in workin order.
Is the pressure regulator right for the type of gas your using...? i had the same problem.i found out that my regulator was for both lp and nat.gas.i also found out there is a small nylon pin underneath the brass cap on top of the regulator.i unscrewed the cap and the fitting was set for lp.and i was using nat. gas.i just pulled the nylon pin out,flipped it around and replaced the cap...works fine now.if your regulator is like mine the nylon pin is maked LP on one end and NAT. on the other.might be worth a try
Posted on Feb 03, 2009
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pilot light won't stay lit on convection heater.
replace the therocouple. next year do not turn the pilot off
Nov 24, 2008 | Clairion Convection Heater - HC-1500
Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater Logo
184 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
