Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
On start up message 'disc failure 19.1' comes on.
Hi guys,
When I start the C2424, it goes through it's start up routine checking ram, usb etc. When it comes to the check on the disc drive it, fails that check with the above message and then sits there flashing lights.
I have removed the disc drive and it's interface cable to try and run it without these, but still get the same message.
How can I initialise the nvram to try and clear the disc problem? Can I just buy a disc and replace it? Can I run the device with no disc drive by inserting a code?
Hope you can help guys...
John
  • vickypgb Dec 12, 2008
    I have the same problem....please help????
  • Paul Douglas
    Paul Douglas May 11, 2010
    Hi Johndavies:
    What is the complete error code for this printer?
    that would help me more if i had that complete error message.
    Example: 19,01.XXX.XX
    pdouglasss
    Novelist:
  • Xerox Expert
  • 297 Answers
POST Error Code of: 19.01 Flutter and then 19 blinks
Check and reseat hard drive cables. Replace hard drive, if necessary.
Hard Drive Part Number is: 121K39240
http://www.sparepartswarehouse.com/Xerox,Printer,Part,121K39241.aspx
You can also contact a local Xerox Authorized Service Partner to see if they will sell you the part.
Posted on Jan 17, 2009
Xerox C2424 printer lights (all) are flashing and the message is disk test and disk failure. What can I do?
most likely the hard drive - must replace, 20 % chance of it being the electronics module. there is no repaing
Nov 05, 2010 | Xerox C2424 Copier
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Won't boot up. the xp logo shows up and it goes to the advanced startup screen. no matter what i choose ( safemode) etc.., it won't boot up. it just keeps on rebooting.
It's an open case... could be practically anything!
First check in the BIOS the configuration for the SATA controller. Try changing it to Native or Compatible (if possible) and see if it boots up.
Next, I would do a Repair installation using the Windows installation disc.
If setup fails in the middle it indicates a hardware failure.
* Do a bad sectors check/repair using HDD Regenerator.
* Try using different memory modules (RAM) and/or other power supply.
* Remove any non-crucial add-in cards such as modems, PCI USB, etc. and see if it helps in any way.
* Try replacing the graphic card or use the onboard one instead (if exist).
Pelu.
Mar 14, 2010 | Computers & Internet
Problem with the Acer One 110: System hung-up
Do you have a backup disc i.e. an operating system disc! as it sounds like you may have to reload the complete operating system. If restore cant be accessed then you will undoubtedly will have to do a clean install!
Jan 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
System boot problem
This is possibly a bad hard drive. If you know the manufacturer of your hard drive you can download diagnostic tools from their site, burn to cd and run diagnostics to check the drive for errors or failure.
Apr 11, 2009 | ASUS A8N-SLI Premium Motherboard
My siste in laws Dell laptop quit after her daughter had used it, neither know what happened but the computer powers on and then a message like, error disc failure or disc read failure something like that...
Hi Debbie!
It sounds like you dell trying to boot up from a disk.
Get in the bios and change the boot seqvence from cd to hdd (harddisk)
Before that, check so the cdrom is empry, so the girl dident forget a disk or something in the cg-sledge.
If the cd-sledge is empty then the bios change will solve our problem.
Good luck
Nic
If you need further help, just let me know
Mar 27, 2009 | Envision EN 9110 19" Flat Panel LCD...
I switch on the computer it starts but gives me a message ''DISC BOOT FAILURE,INSERT SYSTEM DISC AND PRESS ENTER'' I pressed F8 and a blue screen appears which shows the details about my hard drives. I...
i think you attached any usb device in your USB.... or may be some floppy in your floppy drive.. just remove it and then start your system .....
Mar 22, 2009 | Computers & Internet
On my pioneer DEH-50UB the error message 'ERROR 19' is constantly appearing, this is addressed in the mannual however it merley advices you to restart the unit. obviously this is not satisfactory when it...
To my knowledge, ERROR 19 on a Pioneer DEH series indicates failure on the USB connection. This is usually reserve for an iPod direct connection. If you are using such a device, pls:
  • check the Pioneer CD-IU50 USB Interface Cable;
  • reset the iPod;
  • disconnect the iPod and try again;
  • reset the Pioneer by removing the yellow and red connections. Pls note that some versions would require a security code when reconnected. Pls have this ready if and when your particular unit has a security/anti-theft feature;
  • reference page 32 of the manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | Pioneer Car Audio & Video
DISC STUCK AND ERROR 02 MESSAGE
hi, i have a kenwood kvt_725(or did have before some scallywag robbed it) i had a simular problem when ejecting discs i found that if you turn power off and removed face plate and turned ignition off it eventually ejected the disc and worked, or a simular routine with the face plate then ignition etc etc. i know it seems a lame solution sorry but hope it helps.....
Mar 20, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
384 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
