Question about Canon P23-DHV Calculator
Will not do simple math
Every time I try to calculate 1000-490= It turns the 1000 into -1000 and will not do the calculation at all unless I punch it in like 1000-490+= but then the answers are all negatives.
  • Anonymous Jul 04, 2008
    = not working
Yeah, this calculator is kind of odd in that the keys to the left of the numbers ([÷], [×] and [=]) work more like standard calculators, but the keys to the right ([-] and [+]) work more like they're RPN (more common on HP calculators). To calculate 1000-490, type "[CE/C] 1000 [+] 490 [-]". What happens is this: after clearing then entering 1000, the [+]adds it to the last result (in this case 0), giving us 1000. This number is saved when you enter 490, and pressing [-] subtracts it from the last result (1000), giving you 510.
Posted on Feb 14, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How to calculate cube root on simple calculator
That depends on how simple a calculator. I'll give some examples below for calculating the cube root of 8.
On a TI-86, press 3 2nd [MATH] F5 MORE F4 8 ENTER
If the calculator has a "^" or "y^x" key, raise 8 to the 1/3 power. Again, on the TI-86, press 8 ^ ( 1 / 3 ) ENTER
If the calculator has a logarithm key, take the logarithm, divide it by three, then take the antilogarithm. Again, on the TI-86, press 2nd [e^x] ( ln 8 / 3 ) ENTER
On a slide rule, place the hairline over the number on the K scale and read the cube root on the D scale.
Jan 10, 2013 | Texas Instruments TI-86 Calculator
How do I do permutations on the Ti 84 how do I do combinations on the Ti 84
Use the "nPr" and "nCr" commands in the MATH PRB menu.
To calculate the permuations of five items taken three at a time, press
5 MATH left-arrow 2 3 ENTER
To calculate the combinations of five items taken three at a time, press
5 MATH left arrow 3 3 ENTER
Sep 10, 2011 | Office Equipment & Supplies
My TI-30XIIS calculator displays an arrow,an DEG, and a K always on my screen whenever i try to do simple multiplication. it says Syntax error and will not compute an answer.............
I had this problem also and just fixed it. I hit 2nd key...don't hold it, (it should say 2nd in the lower left corner across from the DEG) then click the K button (also the divide key). The arrow and DEG will remain, but do not affect simple math calculations. Hope this helps!
Feb 09, 2011 | Texas Instruments TI-30 XIIS Calculator
Simple math - $200.00 times 22 LCD shows correct $4400.00 Print out shows - $100.00 times 22 equals $4300.00
Sounds like you could have $100.00 in your memory. The LCD will show your current calculation but the print out might include anything you added to M+/-. Try clearing your M*
Jun 17, 2010 | Victor 2640 Calculator
The TI-84 Plus Silver Edition - when dealing with roots and powers - how do you punch in the third root of or the fourth root of... also, how do you punch in ...the 3rd root of 8 cubed? or the 2nd root of...
Press the MATH key to bring up the Math menu. Option 3 gives you cubed, option 4 gives you cube root, option 5 gives you nth root.
For example, 3rd root of 8: MATH 4 8 ENTER gives 2.
4th root of 16: 4 MATH 5 16 ENTER gives 2.
Apr 01, 2010 | Texas Instruments Office Equipment &...
I am trying to get the calculator in "basic math" mode. displaying the answers in "basic form" unless i am selecting otherwise.
The calculator has two Input/Output modes: MthIO and LineIO. Since I do not know exactly what you mean by "basic math" mode or "basic form" I must summarize some properties of each mode so that you can recognize your "basic math" mode.
  1. In MthIO, you have access to the multistory templates to enter fractions with a horizontal fraction bar etc. the exponents for the powers are raised above the main line, etc.
  2. In LineIO, what you enter in calculator is all on the same line, fraction and radical results are displayed as decimal numbers, etc.
The calculator is by default in the MathIO mode. If it not, you can restore it by pressing the key sequence: [SHIFT][MODE] (SETUP) and select [1:MthIO].
To set the LineIO as the default, you press the key sequence: [SHIFT][MODE] (SETUP) and select [2:LineIO].
Hope it helps.
Thank you for rating the solution.
Dec 14, 2009 | Casio FX-115ES Scientific Calculator
How do you do: 3 1/2 + 4 1/8 on the TI-83 calculator I know how to solve it by hand but if I wanted to verify my answer I don't know how to do it on this calculator.
Unlike other, less sophisticated calculators, the TI83Plus /TI84Plus /TI84Plus Silver Edition do not have a simple key or a command for improper fractions. However there is a command -->Frac accessible through [MATH] key [1:-->Frac] that expresses a result in a proper fraction format.
Here is how you would enter you calculation
3+ 1/2 +4+1/8 [MATH][1:-->Frac][ENTER] result is 61/8
You can also ease a bit on the typing by mentally adding 3 and 4
7+ 1/2 +1/8 [MATH][1:--Frac][ENTER]
You should know about the other command that converts a fraction in decimal format. [MATH][2:-->Dec][ENTER]
If you enter this command just after the one handled above, your screen shows [Ans][-->Dec] on one line and the result 7.625 on the next. If you do not enter a number the calculator uses the last CALCULATED result, which is stored in the system variable [Ans]
Hope it helps
Sep 12, 2009 | Texas Instruments TI-83 Plus Calculator
Weird Markings on Screen
Try resetting calculator to default configuration.
[2nd][MEM][7:Reset][2:Defaults][2:reset]. Then [CLEAR] screen.
Hope it solves your problem.
Aug 18, 2009 | Texas Instruments TI-83 Plus Calculator
Canon P23-DHV Calculator Logo
221 people viewed this question
Clive
Clive
old marine
old marine
