Question about RCA F36685 36" TV
Our t.v.'s audio is not working.
Every time we turn the t.v. on the volume automatically goes down and we cant control the volume on the remote. So we have to turn on the warranty lock for there to be sound, which takes up half of the monitor. When i put the warranty lock on it shows the hours it expires. Can we program it on the remote?
Please reply, thank you so much!
Edwin
  • Josh Crager
    Josh Crager May 11, 2010
    Any news?
  • Josh Crager
    have you tried disconnecting the button panel on the tv itself to see if the volume still goes down? Sounds like it could be a bad button.
techman
  • 3130 Answers
SOURCE: Volume goes up on its own and stays up.
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
Posted on Jun 10, 2006
MikeNJ1964
  • 398 Answers
SOURCE: RCA 36 in. tv no volume
It is not a loose solder joint. It is not a faulty capacitor. Usually, a spray cleaner or some other fluid is sprayed or spilled onto the top or front of the TV and it seeps down inside and contaminates the little pushbuttons. If the volume down pushbutton is contaminated, the set will have the exact symptoms you are seeing.I have seen this many, many times, and once I saw a pushbutton contaminated with cigarette smoke. The pushbuttons should be checked and/or replaced by a qualified tech.
Posted on Sep 30, 2007
CLUEPATEL
  • 138 Answers
SOURCE: Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Posted on Dec 23, 2007
falter
  • 245 Answers
SOURCE: no sound
check if u have muted ur sound.....if so just push sound again and it will work......read ur instruction for ur set.....
Posted on Mar 28, 2009
  • 508 Answers
SOURCE: Turns on/off automatically - no control of TV
blow dust out with compressed air
Posted on Jul 08, 2009
The volume knob on my JVC receiver is loose and the volume cant be turned up or down by the knob. Can i use a remote to turn it up or donw or do i have to look for a new receiver?
Assuming your receiver came with the ability to be remotely controlled, then yes, a universal remote such as the Logitech Harmony etc, will be able to control the volume.
Dec 10, 2014 | JVC Audio Players & Recorders
Telefunken vegas please assist and email me maria.vandenberg59@gmail.com some help my TV sound goes up and down one moment it is soft then it goes load. How can I ajust the volume
If the audio level goes up and down automatically, the cuse should be with its main system control memory IC. Contact any service technician.
Gopakumar Gopalan Google
May 17, 2014 | Televison & Video
Tv volume control
the volume controler board on the tv could be at fault. the button could be damaged and connecting the circuit making the volume go up. failing that there is a cross feed some were on the feed were the wire from the control buttons go to the main board, dust a damp can cause this. or even just dust.
Jun 21, 2017 | Coby Audio Players & Recorders
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
When I put batteries back in remote control it automatically turns volume down, when I take batteries out everything seems to work OK manually
It seems like the volume button is stuck on the remote itself. If you can, try and clean the remote and see if you can free that button.
Jan 07, 2011 | Sony STR-DA90ESG
Turns on automatically
use your camera on your phone and point the remote at the camera lense, you will probably find the remote is lit up and the remote is the problem, button on the remote is stuck and sending signal to the tv all the time until the batteries go flat. if its not that then the tv main av controller board has a fault. there area on the board for remote signal control.
Jan 09, 2018 | RCA L37WD12 37 in. LCD HDTV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
RCA F36685 36" TV Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
