Question about Sony Ericsson w580i Cellular Phone
Music and camera not working
Whenever I try and play a music file there's no sound, my alarms don't work and my ringtone doesn't work either it only vibrates. Also whenever I activate the camera it stays at the gray screen.
  • Anonymous Jan 11, 2009
    I have exactly the same problem plz cud any1 help
It may be just on silent.
On the 580i there is a shortcut to muting and unmuting the phone.
When you first open your phone (standby screen) press and hold the # (pound) button for about 2 seconds. When your phone is muted, you will see a music notes symbol with a red line thru it at the top of the screen next to the antenna bars.
This may fix your ringtone problems but I don't know about the camera.
Posted on Jan 19, 2009
Camera problum do not save the photo in M2 card
Posted on Jan 20, 2009
  • 75 Answers
Speaker might be shorted else replace it and if not reinstyall the software
Posted on Nov 27, 2008
How can I make my speakerphone work again?
call someone or tun on music on phone menu select loud
Feb 27, 2016 | Cell Phones
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    I am now using Music Beta, and I realized that one very important feature is missing from the Android App... The ability to make songs your ringtone. I downloaded a lot of songs from Music Beta to my...
    You should be able to use the songs as ringtonesby selecting music instead of system sounds when trying to assign ringtones.
    I know that certain music apps don't allow the songs to show up when trying toassign ringtones. You can move the songs to: sdcard - media - audio - ringtonesand you should be able to find them then. Good luck
    Jul 11, 2011 | BlueTone Android Apps
    Dear sirs. I hope you can help. I just got the droid HTC EVO. i somehow installed a music video that plays and displays whenever I get a phonecall with this terrible clip of some musician. I desperately...
    here are two ways to setup a ringtone for incoming calls.
    1. From the Home screen tap Settings > Sound & display > Phone ringtone. Tap the ring tone you want to use on the list, and then tap OK.
    2. You can also use a music file as a ringtone. To set up a music file as your ringtone, please use the micro USB cable to connect the phone to a USB port on your computer. The Connect to PC dialog box displays and prompts you to choose Disk drive > Done. Your phone's SD card is mounted as a drive on your computer. You can now copy music files to the SD card.
    After you have finished copying, open the notifications panel (by touching and then dragging the status bar down) on your device; then in the Notifications panel, touch Charge only.
    Then tap All programs > Music > tap the music you want to set as a ringtone (the music will start playing) > press Menu > Set as ringtone. You can set the music file as a Phone ringtone or Contact ringtone or you can select Trim the ringtone.
    Jan 16, 2011 | HTC EVO 4G Smartphone
    I have a nokia E72 and have been trying to change the ringtone assigned to certain contacts. When i select ringtone within the options menu i only get a list of the ringtones which come with the phone....
    Select the music file you want inside the media gallery, open the Sound Clips folder where your music file is stored then select 'Option', choose 'Use Tones --> Set as ringing tones' or 'Use Tones --> Assign to contact'
    Aug 18, 2010 | Nokia E72 Smartphone
    Sound isnt working
    Try to change the buzzer. But if your phone still have a warranty, just send back where you buy it. If it isn't the buzzer, you can try to reset to default setting.n It might also works.
    May 11, 2010 | LG Dare VX9700 Cell Phone
    Downloading
    Your computer is full of potential free ringtones for your Samsung T229 (also known as Samsung SGH-t229, T-mobile t229) :
    By Bluetooth:
    The Samsung t229 is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Samsung t229.
    Simply record sound directly:
    Since your Samsung t229 has a sound recorder (also known as "voice memo"), a very simple technique involves simply placing your phone near your computer's speakers, playing whatever music or sound you would like as a ringtone, and recording it -- you can even use your voice, your child's voice or even your cat's "meow!" Record it with your mobile and there you go! Unless that function was specifically blocked on the Samsung t229, you should be able to navigate to the ringtones section and choose your new recording as a ringtone. Of course, the quality will not be ideal but, after all, it's free!
    Downloading using the phone
    NOTE: MegaTones, HiFi Ringers, and Voices & Sounds are stored at Menu > Fun & Apps > Files > Sounds > Sounds. To download using the phone, perform the following steps: 1. At the main screen, select t-zones. 2. Scroll to and select Music & Sounds. 3. Scroll to and select HiFi Ringers, MegaTones, or Voices & Sounds. 4. Scroll to and select the desired category. 5. Scroll to and select the desired tone. 6. On the preview page, select ACCEPT. 7. After the tone downloads, select Play to preview the tone. 8. Select Set as. 9. Select one of the following options:
    • myFaves ringtone: To set as a myFaves® ringtone. Scroll to and select the desired myFaves contact.
    • Default ringtone: To set as the default ringtone.
    • Caller ringtone: To set as a caller ringtone. Scroll to and select the desired contact.
    • Alarm tone: To set as an alarm tone. Scroll to and select the desired alarm. Turn on the alarm and select the desired time and date.
    10. Select Save.
    Apr 27, 2010 | Samsung SGH-i300 Cellular Phone
    I cant set my sounds as ringtones!!!!!!!
    u set the ringtone from mutimedia>sounds,ussally while playing the will be option "set a ringtone" not from digital audio player,directly from sounds.
    motorola does not accpet viruses infected files or their phone must be trying to send virus attachment or ur phone memory will be full.
    Jul 09, 2009 | Motorola Mobility RAZR V3
    I cant have my own mp3 songs for my ringtone on my LG Chocolate. it keeps playing the Ring 1 ringtone.
    You can: MP3 Player * Download and listen to music with the built-in MP3 player.
    * Don’t settle for boring polyphonic ringtones, select an MP3 as your ringtone. (Also supports AAC, AAC+, AAC++ and WMA formats)
    * External MP3 button for easy access to your music.
    * Graphic equalizer with 6 sound effects to choose from (General, Classic, Jazz, Pop, Rock and Bass).
    You should try to find a music or download some mp3 music and when playing click on set as ringtone.
    Jul 28, 2008 | LG Cell Phones
    HELP!!!!!!!!!
    Features of your phone:
    Compact and thin
    • Brilliant TFT internal display with iconic CLI
    • Calendar with event reminder (alarm), alarm clock, stop watch, currency converter, calculator and ringtone composer
    • MP3 ringtones and FM Radio (play FM radio thru speakerphone w/ headset plugged in)
    • Stereo support via 2.5mm headset jack, send/end headset support
    • Speakerphone (office quality)
    • Messaging: SMS, MMS, EMS, and SMS Chat*
    • 100 entry internal phone book with picture phonebook on phone vCard send/receive via MMS*
    • VGA Camera with 4x zoom (1x, 2x, 3x) with special effect options GPRS Class 8 (1 up/4 down)
    • WAP 2.0
    sorry your phone does not support music files (mp3,acc,ect.)
    Jan 19, 2008 | Motorola Mobility W375 Cellular Phone
    Sony Ericsson w580i Cellular Phone Logo
    196 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Sandeep Shenoy
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
