Question about ASUS A8V Motherboard
Asus A8V Error Message
Upgraded to 4 GB Memory, now receiving error message "USB Device Over Current Status Detected!!" using the latest bios ver. 0229 running Vista Ultimate 64 Bit. Had to flash bios to previous ver. 0219 for PC to boot but getting another error message "System does not recognize processor, hit F1 to continue. This issue is far from new I've read horror stories on hundreds of Forums concerning same issue. Is there a real "Fix" is does Asus just not care?
  • 13 more comments
  • dui_lash Nov 27, 2008
    Answers to both questions;
    2 sets of TwinX matched Corsair DDR CMX1024 PC3200 Non Ecc
    (4 sticks 1024 ea.) Timing @ 3 3 3 8 on all 4
    Cooler Master Real Power Pro 750-watt power supply
    And yes if I revert back to my original 2 gigs all is fine, also I tried the new 2 gigs and all works perfect. So the ram is good its a bios issue.
    Comment posted on Nov 27, 2008
  • dui_lash Nov 28, 2008
    I have tried all the bios versions looking for the "Advanced>Memory Configuration setting "DRAM Over 4GB Remapping" it doesn’t show up in the settings. Pg. 4-16 in the Manual shows it to be below "Memclock Mode" but it is not showing up. I have tried ALL the bios versions and don't see it.
    I have to enable "MCT Timing Mode" for the advanced memory settings to expand.
    By the way Wayneard I really appreciate your efforts in trying to help me resolve this issue. If you can find a fix there will be allot of people in the community that will be praising you :) as this is been an ongoing issue for quite some time and Asus doesn’t seem to care.
    Thanks Again In Advance
    Changed Ram voltage from 2.7V to 2.8V dosen't help bios ver. 0219
    Going to flash bios back to the most recent ver. 0229 reset voltage to 2.8V and give it a try.
    System will not Boot into Windows @ RAM voltage 2.8V in either bios ver.
    Had to reset to 2.7V (back to square one)
    Master ECC is set to DISABLED
    DDR voltage set to AUTO
    Will boot and run on 3 sticks but I lose the dual channel mode therefore actualy obtaining a decrease in performance opposed to 2 in dual channel mode.
    I noticed at boot the bios is actually reading 3456 gb RAM which makes since due to the Southbridge resource allocation. Unfortunately windows vista ultimate 64 is only seeing 2048 gb RAM. I go to run/DXDIAG shows windows RAM being used.
    If i right click on my computer and look at the windows experience index it shows 4.00 GB RAM
    I ran a system test at PCPitStop and it also detects a Memory read error, tells me exactly what I'm seeing, I have 4 GB RAM but system is only using 2048. There possible cause is old outdated bios. Yes I'm using a old outdated bios but at least it will allow me to boot up. All the newer versions give me the same error messsage when trying to use 4 GB RAM "USB DEVICE OVER CURRENT STATUS DETECTED!!" System will shutdown in 15 seconds.
    I don't have anything hooked up via USB reverted my mouse and keyboard back to PS2 connections.
    I think the DRAM Over 4GB Remapping setting would possibly help but none of the bios versions actually have it in them.
    Thanks for the Links Wayneard but I read them weeks ago........
    This is Definitely an Asus mb Bios issue that they are aware of and refuse to correct.
    Thank you very much for all your time and effort with this problem.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
  • Wayne Mineard
    I did some searching and found a thread on ASUS site dealing with this problem. May or may not be any help. You seem to be pretty much on the ball. You may have sen it. Anyway, near the bottom of page 1 and most of page 2 there were several things guys did to correct it. It was a different MB, but it looks like ASUS is quite popular with this error.
    Here's the link:
  • Wayne Mineard
    Verify Master ECC Enable is set to DISABLED.
    I would leave the DDR Voltage set to AUTO.
  • Wayne Mineard
    Sorry, I don't think you can install 3 sticks because of Dual Channel mode.
  • Wayne Mineard
    Another question...Have you tried 3 GB? The 2 originals in the blue slots and one of the new ones in the black slot in between.
  • Wayne Mineard
    Great! Thanks for answering. I didn't think it was a power problem, and with a 750W pwr supply, I know it isn't.
    Next, go into the BIOS to Advanced>Memory Configuration>DRAM Over 4GB Remapping and make sure it is ENABLED. Save and Exit.
    There is also a note in the manual that the entire 4GB may not show up due to "the Southbridge resource allocation".
  • Wayne Mineard
    Have you tried to revert to the previous RAM configuration?
    Are the new RAM modules nonbuffered DDR PC3200 or PC2700?
  • 21 Answers
How many whats is your power supply? Sounds like not enough voltage.
Posted on Nov 27, 2008
  • cbri Nov 28, 2008
    Can you up your ram voltage in your bios settings? Maybe they require more power than your old ones..
  • cbri Nov 28, 2008
    Can you up the voltage to your RAM in the bios setup? Maybe they need more power for some reason.
When i start my pc i get the error "please enter
One or more of your USB devices connected to your PC are malfunctioned, remove any usb connection exept keyboard and mouse. Boot the PC , if the error still exists then reboot after removing your Mouse first and keyboard at second. Tell me what happens after these.
Sep 14, 2011 | ASUS P5KPL-AM SE Motherboard
USB Over Current Status Detected, Computer will shut down in 15 seconds
this message popped up because one of the device which you connected to the usb of the pc was overdrawing current i.e more than 5V DC. Hence, the built in system security gave this message and will shut down your computer in 15 seconds. In order to avoid this message first remove all the usb items connected to it and then connect one by one and detect the faulty one and replace.
Jan 29, 2011 | ASUS P5PE-VM Motherboard
Asus P5RD-2-UM acpi bios revision 0811. Press del to run setup Press F8 for BBS popup initializing usb controllers..done. 992mb =32 mb shared memory avto detecting pri master ide hard disk pri master...
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Dec 20, 2010 | ASUS P5RD2-VM Motherboard
Acer P5Q-EM mobo. When trying to boot i get this message USB DEVICE OVER CURRENT STATUS DETECTED WILL SWHUT DOWN IN 15 sec. which it does, I am also unable to get into the bios, even before I get the...
Ive seen this a few times. Its either a usb device plugged into the board shorting a usb port out, or whoever put it together wired the usb ports wrong on the board. FYI its an Asus mb not an Acer.
Sep 07, 2010 | Acer Computers & Internet
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
ASUS A8V Motherboard Logo
395 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
