Question about Panasonic NN-T990SA Microwave Oven
Okay, I've never done this before, so I keep typing in the wrong space. My panasonic inverter microwave - 4 yr. old model no. NN-H664NF - started up & seconds later stopped cold. Nothing is working on it. What could be the problem?
  • 446 Answers
The magnetron is defective you need to send this to a shop im afraid
Posted on Nov 27, 2008
Microwave shuts off after a few seconds. message says to check the manual. What's wrong?
The problem is the magnetron, or the inverter board, "if 7 years old or less" and possibily the keypad control board.
Apr 28, 2012 | Panasonic NN-S262SF Microwave Oven
What does H97 code mean?
Sounds like your magnetron or inverter board.
Is your microwave in a cavity? If the microwave doesn't have enough ventilation space around it then the microwave is prone to overheating. Check your owners manual. Most require 6 inches on top, 4 inches behind, and 2 inches each side. No ventilation = magnetron or inverter will cook itself and fail.
Where we repair them in Australia our repair cost ranges from AU$100 to AU$120 but obviously depends on the model. Price in your location will be different.
May 22, 2010 | Panasonic NN-SD797S Microwave Oven
Overheating Panasonic NN-E225M
i have seen tisquite a lot, simply try and keep open space behind and ontop and u will be ok.
Jul 05, 2009 | Panasonic NN-T993SF Microwave Oven
Panasonic Inverter Microwave, NN-H665BF, Smoking Issue
The magnatron is covered by warranty for 5 years and I just spoke with an authorized Panasonic repair center who said the inverter is covered on this unit depending on the manufacture date, like april 04 to october 05 approximately.
Jan 21, 2009 | Panasonic NN-P294SF Microwave Oven
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
PANASONIC MICROWAVE NN-K657
To UNLOCK it, press Stop/Clear 3 times.
To LOCK it, press Start 3 times.
You can download your owner's manual here:
http://techdocs.panasonic.co.uk/GetDoc.aspx?did=125787&fmt=pdf&lang=en&src=3
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 24, 2008 | Microwave Ovens
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Panasonic NN-T990SA Microwave Oven Logo
181 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
