Question about Canon i80 InkJet Printer
Printer problem what is solution 5100 for a cannon i80 printer
BY NOT PAYING ANY MONEY
Posted on Nov 28, 2008
States error 5100 on our canon i80 printer
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve this error follow the given steps:-
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed.
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
May 15, 2011 | Canon i80 InkJet Printer
It falshes orange and it makes a raddling noise
This error is cauded when there is a issue with the waste ink tank, which in your case will have to be resetted. To do the same please follow the steps as provided in the below article:
http://tricks-collections.com/waste-ink-tank-full-reset-canon-i80/
Also you can visit the cannon website and it tells you in detail the meaning/resolution when the orange light flashes:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i80#ServiceAndSupport
Fo to section "Services and support" and there in the dialog bos type "orange light flshes and it will give you steps to follow.
Please let me know if you need any further information.
Jul 21, 2010 | Canon i80 InkJet Printer
Cannon bubble jet 5100 cant connect
What are you trying to connect to, you computer?
you are trying to install drivers?
have a look here for the drivers
http://software.canon-europe.com/products/0000410.asp
select Windows 2000, if running Windows XP
Jul 19, 2009 | Canon BJC 5100 InkJet Printer
How to fix error 5100.
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab
Jun 29, 2009 | Canon i80 InkJet Printer
Has 5100 error, wont print
5100 is carriage jam error. Open the cover and check the carriage road.
May 23, 2009 | Canon i80 InkJet Printer
Canon i80 service error 5100
Hi guys,
Service error 5100 indicates that carriage return (CR) operation is not performed successfully. After the printer turned on, printer initialize some operation include CR operation. This error happens when carriage part (carriage unit) has problem when move right and left in initialization process.
This may be caused by:
  • Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
  • Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
  • Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
To fix this problem you may try the following tips:
  • Check if any material present in carriage path; remove (clear) it
  • Check if film encoder is dirty; wipe slightly with moistened clothe.
  • At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Please don't forget to rate me.
Regards,
Source:
Inkjet Printer Forum
Dec 24, 2008 | Canon i80 InkJet Printer
Canon i80 error 5100
Hi antoinette,
Someone has ever asked this problem and I have post a solution for this. Here is my answer:
* Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
* Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
* Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
* Check if any material present in carriage path; remove (clear) it
* Check if film encoder is dirty; wipe slightly with moistened clothe.
* At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Best regards,
Source:
Dec 18, 2008 | Canon i80 InkJet Printer
Printer canon i320
Here is the Cannon Service Tool... you should be able to reset the printhead error using this. I've never used it myself, but it is the only fix other than a service call that I know of.
Cannon charges almost $100 for this tool... here its free.
http://221.128.79.71/printersiam.com/data/download/i320toolV101_XP.rar
Dec 07, 2007 | Canon i80 InkJet Printer
Canon i80 InkJet Printer Logo
49 people viewed this question
old marine
old marine
Corne Viljoen
