Question about HP Computers & Internet
Screen will not display. - HP Computers & Internet
  • 4 Answers
Y check ram,after vga cable
Posted on Nov 28, 2008
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The display stopped working, Just a white blank screen. The phone still works but the screen does not. Can't see who is calling and can't retrieve pictures.
Hi,blank screen is usually caused by bad screen or flex depending on the type of phone you are using at the moment.
If the phone is a flex phone that means you will need to check both the screen and the flex.(flex makes the screen to display).
When you replace the screen,the phone display will be working again.
Have a nice day.
Sep 01, 2010 | Cell Phones
Display not comimng up when switched on
The screen cannot display anything, not even the charging display because the flex of the screen of your phone is faulty.
All you need to do is to replace the flex on the screen of your phone in order for the screen to display.
Take care.
Apr 21, 2010 | Sony Ericsson W550i Cellular Phone
Monitor will not display
Your display app controls that, try updating drivers/ software for graphics card on laptop.
Or press the monitor button (usually Fn + something) till it comes right
Aug 08, 2009 | Compaq Presario 705US Notebook
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
Dell 6000 laptop screen blanks out - bought new screen
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Remove the hinge cover.
  3. Remove the keyboard.
  4. Open the display all the way (180 degrees) so that it lies flat against your work surface.
  5. Remove the four M2.5 x 5-mm screws (two on each side) that connect the display assembly to the computer.
  6. Loosen the screw that connects the grounding wire to the system board.
  7. Use the pull-tab to disconnect the display cable from the system board.
  8. If a wireless Mini PCI card is installed, disconnect the antenna cables from the card.
  9. Lift the display assembly from the computer.
Apr 06, 2009 | Dell Inspiron 6000 Notebook
My mobile nokia 7610 has a broken display . can i replace it with a new display screen ?
I have nokia 7610 model, the display screen is broken.
How can I rectify that or what is the cost of display screen
Mar 01, 2009 | Nokia 7610
Nokia K750i
If the new screen is white and old screen displays 20% of the display then you can check by flashing the software , in most the cases white screen is the software problem.....
Aug 17, 2008 | LG M4410 Cellular Phone
Laptop malfunctioning
Connect any Desktop monitor to the Laptop and check whether the Display. if the display is fine on the Desktop monitor screen then it can be identified as the Laptop screen malfunctioning.
And if the Display has the same issue that on the Laptop screen
then it can be treated as the Display card issue.
However, it seems to be Harwre related issue. Get the laptop veriufied under Technical supervision to repair the Laptop's display card or the Laptop screen to be replaced if the display is fine on the Externally connectd Monitor.
Aug 04, 2008 | IBM ThinkPad T40 2373 Notebook
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
Computers & Internet Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
