Question about Acer Aspire 3610 Notebook
I would like to upgrade my aspire3610 by changing the memory to 2 gigs ,do I have to back up the existing memory and is difficult to do
  • ausspain Nov 30, 2008
    fantastic worked like a charm ,I followed the instructions and the whole programme is working.
    Thanks for your help.
    Novelist:
  • 167 Answers
No, but you want to make sure the RAM upgrade you get is compatible with your Notebook. The Acer Aspire 3610 uses PC24200 NONECC Unbuffered 200 pin DDR2 SODIMM RAM modules. It's pretty easy to do, just remove the access panel at the bottom of your laptop, remove the old modules by releasing the clips, pop-in the two new 1 GB modules, and then boot up the system.
Posted on Nov 27, 2008
  • 488 Answers
You will have to fill both slots to increase RAM
please look at this link:
http://www.crucial.com/store/listparts.aspx?model=Aspire%203610%20Series
this is at http://www.crucial.com/
you can use their online memory scanner or the drop down menus,that shall tell you all the details for your system..
please do remember that adding more memory may void your memory..installing is quite simple and its always suggested to back up important data before making hardware changes though adding memory is quite a routine thing..
hope it helps!regards!
  • 41 Answers
This is a fairly straightforward procedure. There is no need to backup anything on your system, although it is good to always keep a backup. I do suggest you keep a backup, but I've upgraded many computers without having to. At least backup your most important documents onto a USB key or an external hard-drive.
Since you are upgrading your RAM and not your hard-drive, you're only upgrading the memory that is used while the computer is on.
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Can I put a 4x/8x AGP card on this motherboard? Also can I upgrade the memory to 1 Gig of PC2100 SDram Non-ecc unbuffered?
The AGP (graphics port) only takes 4x on this motherboard, you can upgrade the memory as far as 2 gig, so yes you can upgrade the memory to 1 gig pc2100.
Feb 06, 2010 | EliteGroup L7VMM2 Motherboard
Is 1 gig of ram enough memory to support vista to run?
Hey there you want to use vista?? lol good luck. You need a min of 2 gigs ram to run vista but should ideally have 4 gigs for good operation. vista is a memory hog. You can change the configuration to use less but still need at least 2 gigs
seth
Jun 27, 2009 | HP Pavilion dv6000z Notebook
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
To upgrade my Asus Eeepc 4G
The only way you can add space is for you to use an external HDD because an Eee PC has a built-in hard drive that cannot be upgraded.
Dec 07, 2008 | ASUS Eee 4G Notebook
Toshiba sattelite
The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
2 gig ram stick
Absolutely, 2 Gigs stick of RAM exist. Unfortunately your motherboard's maximum memory supported is 2GB. This site specifies very clearly 1 gig stick max per slot:
http://www.crucial.com/store/listparts.aspx?model=P5VD2-MX+SE
A.J.
Jan 28, 2008 | ASUS P5VD2-MX SE Motherboard
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Jan 26, 2008 | Sony VAIO VGN-A690 Notebook
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3610 Notebook Logo
143 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
