Question about Canon i80 InkJet Printer
My printer Cannon i80 has a problem , it refers me too 5100 in the manual but i do not have one
  • 2,692 Answers
Service manual
look up the printer tray sir.... if you see a lots of paper inside the tray removed it.. then try again printing... or else... try to change the printer mother board...
Oct 24, 2013 | Canon i80 InkJet Printer
States error 5100 on our canon i80 printer
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve this error follow the given steps:-
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed.
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
May 15, 2011 | Canon i80 InkJet Printer
I get Service error 5C00 for my Cannon i80
Canon USA has a down loadable file for the manual.
Here is the link.
Here is what is being said of this error on the forums:
Fixing this error is much easier as it looks. Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad
Apr 28, 2010 | Canon i80 InkJet Printer
What is error message 5100 for this printer?
Code 5100 refers to a carriage that is not freely moving from side to side. Look to the far left and right for anything that would impede the carriage path.
Also, it is possible that the clear plastic encoder strip just behind the carriage path has become smudged with (most often) grease. You can clean the strip with a cotton swab dibbed in alcohol.
I hope this helps!
Mar 27, 2010 | Canon Pixma MP450 All-In-One InkJet...
How to fix error 5100.
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab
Jun 29, 2009 | Canon i80 InkJet Printer
Has 5100 error, wont print
5100 is carriage jam error. Open the cover and check the carriage road.
May 23, 2009 | Canon i80 InkJet Printer
Canon i80 error 5100
Hi antoinette,
Someone has ever asked this problem and I have post a solution for this. Here is my answer:
Service error 5100 indicates that carriage return (CR) operation is not performed successfully. After the printer turned on, printer initialize some operation include CR operation. This error happens when carriage part (carriage unit) has problem when move right and left in initialization process.
This may be caused by:
* Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
* Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
* Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
To fix this problem you may try the following tips:
* Check if any material present in carriage path; remove (clear) it
* Check if film encoder is dirty; wipe slightly with moistened clothe.
* At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Best regards,
Inkjet Printer Forum
Dec 18, 2008 | Canon i80 InkJet Printer
Printer problem
Nov 27, 2008 | Canon i80 InkJet Printer
Canon i80 InkJet Printer Logo
126 people viewed this question
old marine
old marine
