Question about Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine
Threading bobbin for singer 8734
How do I thread a Singer 8734 drop-in bobbin? The needle will not pick up bobbin thread ..
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Posted on Feb 14, 2010
Thread started bunching on underside of project & tangling around bobbin. Now the needle won't pick up bobbin thread, even after changing needle 2x and re-threading upper thread. What's wrong?
Hmmm, could be several things.
Try a brand new needle. Try a different brand of thread.
Remove the top thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still will not pick up the bobbin thread, the machine could be out of time.
Jan 19, 2018 | Singer Sewing Machines
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
On my Singer 6235 sewing machine, needle will not pick up bobbin thread. Any suggestions to fix the problem?
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Mar 01, 2016 | Singer Sewing Machines
My singer sewing machine still won't pick up the bobbin thread
Doublecheck that your needle in your Bobben are threaded correctly. If they are check to make sure that your needle has been put in correctly, if it is backwards it will not work.
Sep 26, 2014 | Singer Sewing Machines
How totime singer 4423
Make sure the needle is threaded properly. If the thread is going through the needle in the wrong direction, the thread won't be picked up.
Aug 21, 2014 | Singer Sewing Machines
Singer 8734 :my thread is bunching up under the fabric. How do I adjust the bobbin?
If the thread is bunching up, it sounds to me like the stitch isn't being formed properly. Nothing to do with the bobbin, more a case of timing.
The spike, or whatever it is on your machine, which is under the needle, must pass through the loop in the thread from the needle at exactly the right time.
When the needle reaches it's lowest point, as it starts to go upwards again,a loop is formed in the thread,next to the needle eye. This loop is what the spike must pass through in order to make the stitch.
May 19, 2014 | Singer Sewing Machines
The top needle will not pick up the bobbin thread
check your needle placement on the needle holder. if this is out of place or dropped low then this messes with the timing the thread meeting with the bobbin thread.
hope that helps
Aug 19, 2010 | Singer Sewing Machines
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine Logo
669 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
