Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher Paykel 2 drawer dishwasher
Hello, My top dishwasher starts fine and then it gets stuck at 26 minutes and continues to stay lit with the number 26 min on the screen when I am running. No error code is given, it just does nothing. Any tips?
  • 3 more comments
  • phil hall Dec 12, 2008
    My counter stops at 25 mins, the machine carries on washing, then shows F4 fault (temp sensor failure) if left to continue in this state for too long.
  • c_daisymae Dec 14, 2008
    i have a similar problem with both my top and bottom drawers.. the normal cycle gets stuck at 48 minutes, the fast cycle gets stuck on 28 and the delicate cycle sticks at 54 minutes.. i've had the "authorized repair facility" out 3 times so far and counting! what a piece of ****!!
  • slock4582 Dec 18, 2008
    I have this same problem. It stops running and the light blinks and beeps. When I push the start/pause button it resumes and finishes the cycle. It only happens on the upper drawer. It showed a drainage fault. I removed the drawer and drainage tube. No blockage anywhere. We use the fast cycle and it stops at 18 minutes every time we run the dishwasher. Tried running other cycles. Same problem just different minutes. It appears to be when drainage is to begin. Hope you can help...
  • Pedram_5674 Jan 03, 2009
    My Dishwasher is DS603 and it stop on minutes 26 during a cycle and never continue. I have to turn it off and set it to Rinse the dishes. Although it finishes the rinse cycle but still alot of water and foam is at the bottom of the dishwasher.
  • Anonymous Mar 17, 2014
    dd60;, 6 yrs old. screen shoes 05 mins, OR it flashes thru many different codes and numbers continually. inside , the buttons HEAVY, FAST, and ECO are illuminated. standing water in dishwasher from when I ran it at 05 minutes.help?
  • 145 Answers
When it sticks like this, does it continue to wash or does it stop?
Posted on Dec 11, 2008
Fisher paykel dishwasher
If the panel display on the lower drawer is lit and you can select the program then most likely the water inlet valve is fault and needs replacement. But if the panel is dark and none of the buttons operate then the power to the drawer is cut off. This can be due to a number of reasons including the power board at the base loosing one power circuit or the thermal fuse in the drawer is blown. Please provide model number of dishdrawer unit and also please describe what is actually happening.
Jul 30, 2014 | Fisher and Paykel Dishwashers
Fisher paykel dishdrawer
It is likely the top panel of the drawer needs cleaning.
First turn off the mains power to dishwasher and take the plug out if accessible. Wait a little and put the plug back and turn on the mains power. If this does not fix the problem, then get clean damp cloth and wipe the panel buttons on top inside of drawer.
May 17, 2013 | Fisher and Paykel 24 in. DS603H SS...
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Fisher and Paykel 2-drawer dishwasher. The top drawer is stuck in the rinse cycle and I cannot change it to another cycle. Please advise.
Assuming the controller of the top drawer is still ok, take a clean damp cloth and wipe the top panel where the program keys are located.
If nothing happens, you will have to check if the controller connector is not loose. Take the front cover off and check the controller connectors.
Please rate this solution to help fixya serve you better in future.
Sep 16, 2010 | Fisher and Paykel 23 in. DD603H SS...
No power
top drawer turns on runs aprox 3 min then starts to beep and we have to turn it offthe clock pops up and and stays at 2;00
Jul 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Jan 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
507 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
