Question about Homedics SS-4000 Clock Radio
Projection display Purchased two units,both had display segment problems.On one, all segments were lit all of the time-had a display with four 8's. On the second unit, only several of the segments in each number were active-no full number would light. The clock worked fine. I gave up. Back it goes-again!!! unhappy
  • 3 more comments
  • Irked Dec 27, 2007
    Only the top half of the time shows with the projection display. Brand new.
  • mo-mo Feb 11, 2008
    The projection Feature does not work properly and when the snooze button or the projector 'on' feature is activated, the numbers are unreadible and do not light up properly.
  • Anonymous Dec 27, 2008
    Same problem, will try listed solution
  • kear1kei Jan 05, 2009
    Ten8 THANK YOU!!!! Worked like a charm. We were ready to return it (2nd time) and would have never tried this w/o your help.
  • Anonymous Mar 24, 2014
    Unit was covered up with a shirt by baby sitter because the light on display was to bright. All went black after a period of time. Now the temp shows and radio works but the LED time display numbers are messed up. If you need to call the number is 903-539-3559. Thanks for any help.
To fix the projection display that is stuck with four 8's, hold down the hour and miute button at the same time. Keep the buttons pressed down while unplugging the power source then pluging it back it. I did this and the screen works like it did when I first got it.
Ken
Posted on Jan 25, 2008
SOURCE:
Samsung range with digital display not working properly. Clock shows half of the numbers.
Replace the display board. There will be a segment driver that has failed.
May 06, 2017 | Samsung Ovens
Display problem
Fixya does not sell replacement displays.
Oct 28, 2017 | Audio Players & Recorders
Not clear dlsplay with some misssing segment of figures
there are four diodes for the display and the other lights on the face . take off the bottom cover ,look for the they should be together,replace all four. that should do it
Nov 16, 2013 | Radio Communications
HOW DO YOU SET THE CLOCK ON THE DEP-P4000UB
STEP ONE (PRELIMINARY): With the key in the ignition, turn the ignition to ACC (accessory power) or this can be done while the vehicle is running. If unit remains off, proceed to the next step, but if unit is already powered on, power it down by pressing [Source] until it goes off. (Then, proceed to the next step.)
STEP TWO: Press MULT-CONTROL & hold until CLOCK SET displays. (To cancel at any time, press [Band/ESC]. Press [Back] to return to previous display.)
STEP THREE: Press MULTI-CONTROL to select the desired segment of the clock display to set. Each time MULTI-CONTROL is pressed, it selects (blinks) one clock display segment: Hour - Minute.
STEP FOUR: Turn (or push) MULTI-CONTROL (up/down) to change the clock display segment setting.
Apr 10, 2011 | Pioneer Car Audio & Video
How do I change the time? All I see in the manual is the clock button, but it doesn't say what to do after that.
According to the manual for this specific unit, the steps to set the clock are as follows (with minor editing for clarity):
MULTI-CONTROL Being the round knob on the radio.
1 Press SOURCE and hold until the unit
turns off.
2 Press the MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Use the MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
4 Press MULTI-CONTROL to display the
setting mode.
5 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
As you select segments of the clock display,
the selected segment blinks.
6 Turn the MULTI-CONTROL to set the clock.
You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Mar 14, 2011 | Pioneer DEH-P4100UB
I have the cobra CXT275 they have been on the desktop charger for 5 days. They won't charge over a 1/4 of the way how do I get the maximum charge?
Just went to their site and this is what it said:
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Jan 12, 2011 | Cobra Two Way Radio
The sound is not working on my Wurlitzer. The disc spins and if I try to higher or lower the volume, I hear the speakers sort of make noise but not music. Please help . . .
If it is a later model with the black amplifier there is a red digit 8 lit up on the amp. When the amp is unmuted only the bottom segment is lit. If the top and bottom segment are lit the amp is not being unmuted.
Jan 09, 2011 | Wurlitzer Jukebox 1015 One More Time...
How do i change the time on my deck
Adjusting initial settings
1 Press SOURCE and hold until the unit turns off.
2 Press MULTI-CONTROL and hold until CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select CLOCK SET (clock)
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select CLOCK SET.
2 Press MULTI-CONTROL to display the setting mode.# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment of the clock display you wish to set.
Each time you press MULTI-CONTROL, one segment of the clock display is selected.
As you select segments of the clock display, the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock right.
# You can also perform the same operations by pushing MULTI-CONTROL up or down
Jan 09, 2010 | Pioneer DEH-P4000UB CD Player
How to set the clock pioneer dep p4100
Press SOURCE and hold until your head unit turns off. Press MULTI-CONTROL and hold until Clock Set appears in the display. Press MULTI-CONTROL to display the setting mode. Press MULTI-CONTROL to select the segment of the clock display you wish to set. Each time you press MULTI-CONTROL, one segment of the clock display is selected (Hour-Minute) As you select each segment of the clock display, the selected segment blinks. Turn MULTI-CONTROL knob to adjust blinking segment.
Reference page 29 in your instruction manual.
Jan 04, 2010 | Pioneer DEH-P4000UB CD Player
Install setting for Clock and Calendar
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
Your Owners manual
Setting the date
The calender display adjusted in this mode appears
when the telephone source is selected
or sources and the feature demo are off.
Calendar.
2 Push MULTI-CONTROL left or right to
select the segment of the calendar display
you wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the calendar display:
Day—Month—Year
As you select segments of the calendar display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the date.
Setting the clock
1 Use MULTI-CONTROL to select Clock.
wish to set.
one segment of the clock display:
Hour—Minute
put a clock right.
Note
You can match the clock to a time signal by
pressing MULTI-CONTROL.
! If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes 10:00.)
! If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
Jan 01, 2009 | Pioneer DEH-P7900BT CD Player
Homedics SS-4000 Clock Radio Logo
440 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
Vincent_G
Vincent_G
ray gallant
ray gallant
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
