Question about Mitsubishi WD-62531 Projection Television
Green Blinking Light plus Red Lamp Light
I have a Mitsubishi WD-62531, and I recently turned it on only to get a green blinking light while the fan goes on, no picture, then a red light on the lamp. There seems to be some sort of winding sound as well. I tried leaving the television off for awhile, but to no avail it was no quick fix. Any suggestions?
  • venussuperst Dec 10, 2008
    I have a similar thing going on. My tv just turned off this afternoon. "click" red light. I tryed turning it back on and I got a few seconds of audio then "click" red light. I unplugged it for 15 minutes, turned the tv back on held the reset button for ten seconds, crossed my fingers and tried turning the tv on again. But like before a few seconds of audio then "click" red light. This tv is less than 2 years old!!!!!!
  • Anonymous Dec 22, 2008
    i have a similiar problem. tv sounds like its turning on, green light flashes and few seconds of audio and then everything turns off. and a red light appears
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Posted on Dec 13, 2008
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
My mitsubishi WD-65735 1080P has a green blinking light under the word lamp..what does that mean?
all these sets have a boot up if unplugged.
If power is lost or disconnected when reconnected green light will blink for about 70 seconds (set is rebooting) and then go off allowing set to be turned on.
Mar 12, 2012 | Mitsubishi WD-65735 Television
Turned on TV and had no picture. Now when I reset I get green blinking light then solid green status. After about 30 seconded red lamp light comes on. Is there a solution?
Your lamp is defective, incorrectly installed, or the cooling fan under the lamp is not cooling the lamp for some reason. Service that area.
Jun 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
Just replaced bulb two days ago and now theres no picture
there could be a couple of things causing thie, make sure the lamp is all the way plugged in, make sure the lamp door is on and completily closed, also if a fan is stuck and cant spin, also the ballast can cause this, that is the small board that lights the lamp
Jan 11, 2009 | Mitsubishi WD-62531 Projection Television
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62531 Projection Television Logo
429 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
