Question about NetGear DG834G Router
DG834Gv3 will not have password as password admin ok
Router will not allow password to be used
  • terrybrennan Dec 09, 2008
    i used both admin & password for password
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    what password did u use?admin or password?
    New Friend:
  • 128 Answers
There is a reset button on the unit - press for 30 seconds then the unit will be set with defaults - including the password
Posted on Nov 28, 2008
For got password would like to reset username
Every router I have ever seen allows you to reset the configuration to factory default - but not allow you to retrieve a forgotten password and maintain your settings at the same time. This is often referred to a "factory" or "hard" reset.
When you initiate a factory / hard reset, typically by pressing & holding a button on the router - or behind an opening in the router case - all the changes you've made to it will be returned to the factory default. Wifi becomes "open" with no password (on most devices), the login username / password also go back to default settings (common ones are: admin / admin, admin / password, <blank> / admin, <blank / password, etc.). Consult your router's set up guide or online documentation to learn what the factory / hard reset procedure and the default settings.
Once you gain access to the setup pages of the router, configure it as best as you can remember, and lock it down with good security settings. At minimum - this should include changing the router's username / password, the WiFi's SSID and do not broadcast it, add WPA or WPA2 encryption and secure it with a security key (use a mix of numbers, letters, symbols etc.).
I suggest recording the settings on paper and then tape it to the bottom of the router. There it will remain out of sight - but ready when you need it.
Oct 17, 2014 | Computers & Internet
Tip
Solution for War Craft 3 behind Linksys routers.........
As the application requires certain ports to be opened on the router,try to follow the steps below to configure the router. Since you are connecting behind the router, you are going behind a NAT firewall.Therefore, you would need to allow ports for the remote access application to go through the firewall. You would need to know what port number application uses. You can check with the program manufacturer for the information, or see the Help menu.
For routers with old firmware versions (without the Cisco web interface):
1.Open Internet Explorer.
2.After "Internet Explorer" opens, please typehttp://192.168.1.1 into the "Address Bar" and click GO.
3.The "Enter Network Password" window will appear. Skip username and type admin (admin is the default password) as the password,and click OK.
4.You will need to click on the Advanced tab to the very right. Once the "Filters" area appears, please click on the Forwarding tab.
5.Once the "Forwarding" area appears, click the Port Triggering button. Once you've done this, a new window will appear.Enter the ports needed to be opened > Click Apply
For later firmware (that has the Cisco web interface)
4.Click on "Applications and Gaming" then click on the "Port Triggering" Sub tab. Enter the ports needed to be opened >Click Save Settings.
Example:
Customized Trigger Port Range Incoming Port Range
Application From ~ To From ~To
WARCRAFT 6112-6112 6112-6112
WARCRAFT 6113-6119 6113-6119
Hope this help everyone that has problem with the game.
on Jan 05, 2010 | Linksys Wireless-G Broadband Router
Tip
How to Upgrade Firmware of Linksys routers........
Example:
on Jan 05, 2010 | Linksys Wireless-G WRT54G Router
Can not log in right using my username and
Oct 16, 2014 | Computers & Internet
Need to unlock to use different network
If you're referring to "resetting" your wireless router, you only need to press a hidden button at the back of the router. Find a small hole at the back and press it using a thin object like toothpick or a wire. Press it for at least 15 seconds. After doing that, connect one PC to the router using LAN wire and log-in to the router's default address. Since you did not mention what modem you have, here are the options;
192.168.0.1 192.168.1.1 Use default Username and Passwords to set up new Wireless Protocol. Here are possible options;
UN: admin PW: admin
UN: admin PW:
UN: admin PW: password
UN: admin PW: 1234
From here, if you can log-in to Router's IP, look for the Wireless configuration options. It will allow you to set Network Keys and other security options.
Jun 04, 2011 | Computers & Internet
How do I change the ssid and make secure
Securing the router:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696
Changing SSID:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 05, 2011 | Linksys Wireless-G WRT54G Router
DG834Gv3
RECONFIGURE THE ROUTER:
1. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 in address bar.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6lick on Setup Wizard and then select country and language then "Yes" and Click "Next" on the detection window.
7 It should give you a pppoa or pppoe detected"(type the Username & Password of your dsl account infomation which you got from isp)
8 Click Apply.
9 Open up another browser window and try to access internet.
regards
prakash
Jan 23, 2010 | NetGear DG834G Router
How do I set NETGEAR DG834G v3 wireless router
Please follow the following link for any FAQ's on the NETGEAR DG834G v3 wireless router.
http://kbserver.netgear.com/products/DG834Gv3.asp
Nov 14, 2009 | Computers & Internet
We need a password for our belkin router
Reset the router to default, then setup a new password:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Then go to 192.168.2.1 leave the password blank and click submit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 13, 2009 | Computers & Internet
No Passwords Accepted
If u have the switch
for the three desktop OK
Then connect your LAN cable directly to the router.
listen connect cable switch to router then router to laptop and then give automatic ip address in your laptop OK or ipconfig /release give this command and then give command ipconfig /renew then connect to your 192.168.1.1 its connect ok
Feb 12, 2009 | Linksys Wireless-G WRT54G Router
NetGear DG834G Router Logo
302 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
