Question about Freezers
Freezer only freezing to 20 degrez
Freezer door was ajar for a few days, now it is only cooling to about 20 defrees and there is water on the floor , maybr froom the few days being ajar but it used to cool to zero,,,,?
  • 828 Answers
If the door was left ajar for any extended period frost has built up on the cooling coils. A complete defrost of the freezer should take care of the problem. Normally a frost free system will clear the ice from the cooling coil when the defrost time cycle happens. However frost may have built up in areas where the heaters can not readily remove it in a normal defrost cycle and shutting the unit down with the door open for about 24 hours should clear it out.
Posted on Nov 28, 2008
Upright freezer door was left ajar. The alarm keeps sounding, can you tell me where the reset button is located.
Hello Deena;
My name is Peter. I am a retired field service refrigeration technician.
There is no reset for the alarm. The alarm goes off when you are not maintaining temperature.
During the time the door was ajar, warm air got into the freezer either icing up and locking the cooling fan or forming a block of ice on the cooling coils (Restricting cooling air flow.)
The best thing you can do, unless you want a $300.00 plus service call to defrost everything, is to turn power off to the freezer. Open the freezer door. Have plenty of old towels to soak up the water in the bottom of the freezer as it defrost.
You did not provide a model number which is located on the inside wall of the freezer. Every 8-10 hours your freezer will completely shout down for 20-30 minutes where only the light works and the defrost heater turns on. The ice build up is too much for the defrost heater to handle.
In some freezers the defrost mode is in the control board, in others it is a separate component that you can repeat trip using a flat head screw drive.
Jan 26, 2016 | Freezers
Why has my kenmore elite trio refrigerator started to intermittently started to chime
Hi! I am having this exact problem also. The best answer I have been able to discover is that it is related to the freezing up of the internal water tube that drains the fridge compartment into the freezer section. In addition, a pool of water freezes on the interior floor of my freezer and has to be manually chipped up and removed. I did try to unload the freezer and defrost it thoroughly, but it still happens and has to be chipped each week. I am still seeking a solution, but at least I can make the chiming stop by locking the temperature via the button on the front panel. Best wishes. If you discover a better or final soln, please post. I will do so as well.. Regards.
May 28, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My frigidaire freezer upright has an error message door ajar
Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
Sep 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door was left ajar and it wiil not freeze
sounds like the freezer probably over worked the compresser pull fridge bottom cover off and look for frost or the condenser fins might be on back if you see frost on either one you need to turn it off and let the frost melt then start it up again
Nov 07, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Have a frost free freezer kids left door ajar all
You should unplugged and let all the ice melt and help it with a hair dryer.
Oct 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
207 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
