Question about D-Link AirPlus DI-524 Wireless Router
DI-524 WAN LIGTH
Dlink DI-524 wan led is not ligth-Please update on the reasons behind?
  • bompart Nov 27, 2008
    the electrical plug and adaptor is ok, after plug the adaptor to the router all the indicator led ligth lit and only still lit the power, the WLAN, the link and status is blinking, but WAN dont.
    I change the cable to this point but nothing change.
    In this conditions is possible tha the router is damage ?
  • 446 Answers
Ensure that the electrical plug is intact, if you saw no led light lit at all on all indicator check the adaptor itself, if you have a tester you can try to test the end connector to see if there is a DC power line that is coming out.
if not either the adaptor is defective nor the reouter itself is burned out
Posted on Nov 27, 2008
Can't Connect to Internet Using DI-524
Most routers the default address is 192.168.0.1 unless you havve a modem that takes that address.
Sep 25, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-524 is not communicating with modem
Checklist:
* Is DHCP configured correctly?
* Connect your server and laptop to a switch (not directly with the cable)
* Can they ping each other?
* Check that the firewall is configured (or switched off if you have another FW in place)
* Default gateway should be your router, not the computers (until you have configured RRAS for example)
Here you can find more information about how to configure various roles in 2008: http://technet.microsoft.com/en-us/windowsserver/2008/default.aspx
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
Di-524 to netopia 2210-02 wan drop
set a pc inside the network to issue a "ping" command to any website every 5 mins. that will keep the link alive. you can either write a script or use a program such as ws watch.
Dec 04, 2008 | Computers & Internet
How can i configure dlink WAN settings?
I cannot find the version of the dlink..but it an older one...it is Dl-614+
Nov 09, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Sep 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
AT & T Hook up to D-Link
If those lights are lit, they often have a "Code" this code is in the manual. Please find below a link for the manual I am sure all will be found in it. ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf Oh & I am sure ya can connect another WiFi'ed PC no prob's.
Sep 15, 2007 | D-Link AirPlus DI-524 Wireless Router
Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Aug 17, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
214 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
