Question about Sony PlayStation Portable (PSP) Console
Battery is there anywhere i can get a picture to show me where to solder the three pins back to inside the psp so battery can go back in.
    Guru:
  • 134 Answers
Posted on Nov 29, 2008
Hi, I have a samsung samtron 55V 15 inch monitor. The problem is it is not displaying the actual colors. The red color appears as a greenish/bluish shade. Ex: The Windows Start button is showing as light...
You have to check for dry soldering in the base board of you mointor. The base board is on which is attached to the picture tube neck. In most cases there will be dry soldering in the pins of cathode diver ic in that base board. It will be difficult find out which pin have the dry soldering. Do on thing resolder all the pins of that ic. This ic cotrols the three cathodes of picture tube (red, blue, and geen) is any one did not get the correct drive that color will fail to display. In your case the red cathode is not getting the drive voltage. Thats why it shows only gree and blue. This is a reular complait for crt monitors.
ok
Jul 17, 2011 | SAMTRON 55V 15" CRT Monitor
No picture but with sound
There are three things you should try. If you can safely pull the back cover out safely, do so. First thing to look for,is the suction cup attached to the picture tube securely? Be sure that it is. Make sure the TV is not plugged in, when you check for a good ground to the Tube (suction Cup). Then plug the TV in and power up. Still no pic? If you feel that this is not the problem, next, pull the board out of the TV. Be sure to discharge the picture tube before you remove the suction cup. Unplug the TV. A wire taped to a flat screwdriver, the other end of the wire connected to the silver braid that surrounds the picture tube. Now slip the screwdriver under the suction cup, you will hear a snap, you have discharged the tube, you may remove the suction cup. And you may pull the board completely out of the TV. Find the vertical IC and resolder the 7 or 9 pins. Do not use excess solder and short the pins together. Each pin must soldered individually and not together. Check for bad solder grounds on the horizontal transformer. This transformer is usually a small square box with five or six pins. When not soldered with a good ground, it will crate the problem you describe. Next, solder the pins on the Flyback Transformer. Resolder any and all power resistors. A power resistor is one of two watts or more. I do not believe your horizontal transistor is bad in this case, you resolder this as well. A bat transistor would hand you a dead TV. Do go over the rest of the board and really look close for any and all bad solder grounds, solder as necessary. Last be sure you have good solder grounds on the back of the small board that connects to the picture tube. I'm sure you will get your picture back, try all of the above and let me know how things go. Thanks for asking and show all hands of support!
Jun 23, 2011 | Sharp 27R-S50 27" TV
My ds slot does not show up on my choose games even though i put the games in it says 'no ds card inserted" please help me i have my ds but only the gba slot works
There is probably one or more bent pins inside the top slot (SLOT 1). Remove the battery by removing the battery cover on the bottom (held ny a screw). Shine a small torch into SLOT 1 and look inside to see if any of the pins are bent differently to the rest of the pins. If any pins are bent they can be bent back to their correct positions by using a suitable small tool such as a precision screwdriver. If a pin is actually broken then the complete slot will need to be replaced.
If it is not a bent or broken pin, there may be some other type of blockage inside SLOT 1.
If there is nothing wrong with the pins and there is no blockage inside the slot, then there may be a dry joint where the slot is soldered to the PCB inside the DS. This kind of fault will require the DS to be opened with a special tri-wing screwdriver and the use of a multimeter to check all the connections. If you have soldering experience (and tools) then you can try re-soldering the connections.
Be advised that opening the DS is much easier than putting it back together again!
Feb 14, 2011 | Nintendo DS Lite Console
I downloded videos from my pc to psp but I cant find the videos anywhere on my psp. how do I get into my psp memory stick?( I have checked under music,picture,and video sections. )
you've got to copy them to the correct folders or else they won't show up. Videos go into the video folder, music into music, etc. etc.
Oct 10, 2010 | Sony PSP-3000 Black Console
PSP charged all night and will not power on
You're not being clear.
You say "I get nothing"
Do you get a green light? Or no green light?
What if you plug it in? Do you get a green light if it's plugged in with no battery inside?
If you get a green light with the battery in but nothing on the screen, your PSP is bricked.
If the PSP works while plugged in but not with the battery it's either having motherboard problems or the three prongs on the back of the PSP are not making good contact with the battery.
Mar 16, 2010 | Sony PlayStation Portable (PSP) Console
My psp wont charge. The battery went flat and now it wont charge. i have tried it on the mains and through my pc.
Hi it would be the fuse on the circuit board or the pin in the charge plug loose look for diagramme for fuse thru google for your model or replace the power charge cable which ever the problem The fuse you need soldering skills and a fine soldering iron or mabee its the battery try to charge it in a friends first. 1xxx will fit into a 2xxx but not visa versa
Your a big help so far and I see a coin looking super thin but soldered I think. What remove it and solder it back? Wait several minutes and then reset the password to Bios?
Some BIOS batteries do have wires soldered to them but the easiest way to disconnect is remove the plug from the oBo at the other end of the wires. Saves soldering.
Or you could look for the BIOS jumper pins which should be located near the battery (three Pins) Pin 1&2 will be shorted with a jumper. Move jumper to pins 2&3 for 30 secs and move back. Job done.
Feb 09, 2010 | Office Equipment & Supplies
Psp battery
A local electronic shop will be able to repair that very easily....Or if you have the tools then resolder a new set of pins by opening up the PSP.
Nov 25, 2008 | Sony PlayStation Portable (PSP) Console
Bricked PSP
Pandora Battery or Pandora Magic Stick, is psp utility for universal psp unbricker-downgrader- and updater.. the latest version of its utility is DC7..
To create pandora battery you need a psp with custom firmware ready or you can makes its with your PC. The software is open source by psp homebrew development.. that mean its free of charge...
You can't use other battery except psp battery, because psp battery has internal decoding to boot your psp into recovery menu... and has 3 pin battery for it.
If you would like to create your pandora it self, you can find most of our tutorials (all about psp homebrews) at our blog at http:e-arena.blogspot.com
Hopefully this be of some help/idea. Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
Nov 24, 2008 | Sony PlayStation Portable (PSP) Slim...
How to install a new charging plug inside the scanner?
If I am picturing this correctly I see two senerios, you have a 3 point pad and the trace is broken between each of them. Then you could try soldering a #30-36ga buss wire across each of the breaks. Use a very fine tip low watt soldering iron and 60-40 solder with very little flux. Delicate operation, use patience. You should take the board out of the case if possible. If your are really "good" you could "pull" a solder bead across each break. The other picture I have is the whole connection is pulled up. Down side is you may have also broken the solder pads inside and through the board. If that is the case can't be fixed. But try re-soldering it back down to the board by pushing down at the same time heating with a soldering iron. Hopefully you won't short anything. You may get lucky and suceed.
Aug 02, 2007 | Uniden BC60XLT-1 Handheld Scanner
Sony PlayStation Portable (PSP) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
