1992 Mercury Topaz Logo
Posted on May 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the fuel filter - 1992 Mercury Topaz
Randy Handy
Level 3:
  • Master 496 Answers
  • Posted on Jun 01, 2012
Randy Handy
Master
Level 3:
Answers
496
Questions
Helped
248866
Points
1752
The Fuel Filter is located: FUEL FILTER 1992 Mercury Topaz 3.0L FI 6cyl FUEL FILTER 1992 Mercury Topaz 2.3L EFI 4cyl The Fuel Filter is located: Under hood, passenger side, upper engine area, mounted in fuel line The Fuel Filter is located: Under hood, passenger side, upper engine area, mounted in fuel line
lisa jenkins
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 09, 2015
lisa jenkins
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
964
Points
Where is the fule filter on 91 park ave
Fuel filter where is it 2005 chevy tahoe 5.3 liter
Fuel Filter
The fuel filter is contained in the fuel sender assembly inside the fuel tank. the paper filter element of the fuel filter traps particles in the fuel that may damage the fuel injection system. The fuel filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement.
1helpful
Where is fuel filter on 2010 chevy express 6.0 liter V8.
2 of them........First Fuel Filter
One fuel filter is in the fuel pump of the Express Chevy 3500, which is used to push fuel or gasoline through the fuel line. The fuel pump is inside the gas tank. This fuel filter is a mesh or screen that prevents large foreign particles for entering the fuel pump. Access to the fuel filter is obtained by removing the fuel tank and then the fuel pump from the fuel tank.
Second Fuel Filter Location
The second fuel filter is within the fuel line itself. After the fuel pumps extracts fuel from the gasoline tank and into the fuel line, fuel flows through the line and through another filter on the driver's side of the Express Chevy 3500 under the front wheel suspension. This fuel filter cleans the small particles that escaped from the fuel tank.
Fuel Filter Types
The year of your Chevy Express 3500 determines what type of fuel filter is installed on the van. The fuel tank filter is always mesh or screen, but the fuel line filter can be of three different types. Two types are snap-on filters, while one type has clip-on ends.
Where is 2004 avalanche fuel filter
IMPORTANT: This vehicle has a lifetime fuel filter built into the fuel sender inside the tank and thus is not serviceable separately. The fuel filter is not a replaceable part.
1helpful
2answers
How to change 2002 2.8 4bj1 fuel filter
your diesel engine should have a center bolt holding fuel filter it in place.you place drain pan under fuel filter when you remove top center bolt while holding fuel filter then remove old fuel filter then take new fuel filter add few ounces clean diesel fuel in new fuel filter lubricate gasket new fuel filter cartridge then install new filter crank engine check for leaks.
Is there A in line fuel filter on A 2001 grand am 3400 and if so where is it
Fuel Filter Removal & Installation To Remove:
NOTE: There is no maintenance schedule for fuel filter replacement. Replace the fuel filter if restricted. Inspect the fuel tank internally if you find a restricted fuel filter.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Relieve the fuel system pressure.
  3. Raise and safely support the vehicle.
  4. Remove or disconnect the following:
    • Quick connect fitting at the fuel filter inlet
    • Fuel filter outlet fitting from the fuel filter while holding the filter fitting with a back-up wrench
    • Fuel filter from the vehicle
    • Fuel line O-ring.
To Install:
  1. Position the new fuel filter in the bracket.
  2. Install a new plastic retainer on the fuel inlet line.
  3. Lubricate the new fuel pipe O-ring with clean engine oil.
  4. Install the fuel pipe O-ring.
  5. Reconnect the fuel outlet line to the filter by holding the filter with a back-up wrench and tightening the line fitting to 20 ft lbs (27 Nm).
  6. Lower the vehicle.
  7. Pressurize the fuel system and check for leaks.
2helpful
Cant find where the fuel fillter is located in our pontiac Grand am 2004
Fuel Filter (behind gas tank) Removal & Installation To Remove:
    • Fuel line O-ring.
To Install:
6helpful
2answers
How to change the fuel filter on a suzuki grand vitara 2.0td with RHZ engine
Fuel FIlter - Removal
  1. Relieve fuel system pressure.
  2. Remove or disconnect the following:
    Negative battery cable Fuel lines from the fuel filter Fuel filter
To install:
  1. Install or connect the following:
    Fuel filter and tighten the bracket bolt. Note the fuel flow directional arrow. Fuel lines to the fuel filter. Negative battery cable
  2. Start the engine and inspect the fuel filter connections for leaks.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Relieve fuel system pressure.
  3. Remove or disconnect the following:
To install:
Fuel filter is incorporated in fuel pump assembly in fuel tank.
Hope this help.
Looking for fuel filter on 2004 chevy silverado ss 6.0, not on frame rail
Here is the steps for the removal and replacement...getting you the picture and location next. 6.6L Engine
  1. Disconnect the negative battery cables.
  2. Drain the fuel from the fuel filter as follows:
    • Install a hose on the water drain on the water-in-fuel sensor.
    • Place the other end of the hose into an approved container.
    • Drain as much fuel as possible from the fuel filter housing.
    • Tighten the water drain on the water-in-fuel sensor.
    • Water-in-fuel sensor harness connector
    • Fuel filter from the fuel filter/heater element housing
    • Water-in-fuel sensor from the fuel filter
Exploded view of the fuel filter (2)—6.6L engine
To install:
    • Water-in-fuel sensor in the fuel filter
    NOTE Check the fuel filter/heater element housing and the filter for a dislocated filter seal or foreign debris. Contamination on the filter/heater housing may cause leakage at the fuel filter. Coat the seal with clean engine oil.
    • Fuel filter on the fuel filter/heater element housing
    • Water-in-fuel harness connector
    • Negative battery cables
  2. Prime the fuel system:
    • Pump the primer located on top of the fuel filter 30 times or until stiff.
    • Try to start and run the engine. If the engine does not start, repeat the previous step.
    • Allow the engine to run for 5 minutes at idle.
    • Check for fuel leaks and clear all Diagnostic Trouble Codes (DTCs).
I need to replace my fuel filter. need to know where it is and what i need to do to access it.
Regarding Fuel Filter - Under vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line.
A device located in the fuel line to remove impurities from the fuel before it enters the carburetor or injector system.
INSPECTION
Fuel filters can be located in a fuel line, in the tank, in a carburetor, or in any combination of these. A carburetor often has a filter behind the fitting at its fuel inlet.
A carburetor inlet filter. Courtesy of General Motors Corporation, Service Technology Group. Fuel filters that are installed on the outlet side of a fuel pump are called outlet filters.
An external fule filter. Courtesy of General Motors Corporation, Service Technology Group. Engine heat causes fuel to vaporize, which can result in vapor lock in the filter. Some fuel filters have vapor return lines to allow for expanding vapors and fuel to return to the tank.
A fuel filter with a vapor return outlet. Courtesy of AlliedSignal Automotive Aftermarket. Fuel injection systems require larger, heavier duty filters than carburetors. They filter out smaller particles of dirt while still allowing the pump to supply a substantial amount of fuel.
REPLACE
Fuel filters and elements are serviced by replacement only. Some vehicle manufacturers recommend fuel filter replacement at 30,000 miles (48,000 km). Always replace the fuel filter at the vehicle manufacturer's recommended mileage.
The fuel filter replacement procedure varies depending on the make and year of the vehicle and the type of fuel system. Always follow the filter replacement procedure in the appropriate service manual. The photo sequence below shows a typical procedure for relieving fuel pressure and removing a fuel filter.
Removing a Fuel Filter on an EFI Vehicle
Disconnect the negative cable at the battery.
Loosen the fuel tank filler cap to relieve any fuel tank vapor pressbae0f2b.jpga678067.jpg
Connect the fuel pressure gauge to the Schrader valve.
Install the free end of the gauge bleed hose into an approved gasoline container, and open the gauge bleed valve to relieve the fuel pressure.
How to replace fuel filter on a Mercury Village '95?
go here for help on villager issues
http://autos.groups.yahoo.com/group/villagerquest/
It's unde the hood, on the firewall, on the driver side.
Fuel Filters In-Tank
Removal and Installation
The in-tank fuel pump filter is not serviced separately. To service the fuel pump filter, replace the fuel pump (9350). Refer to the procedure in this section. In-Line
Removal
The following illustration is an exploded view of the fuel filter (9155).
Item Part Number Description 1 9K299 Fuel Filter Upper Hose 2 9A335 Fuel Filter Bracket 3 — Fuel Hose Clamp 4 9C323 Fuel Filter Lower Hose 5 9155 Fuel Filter 6 — Fuel Hose Clamps
  1. Relieve the fuel system pressure. Refer to the procedure in this section.
  1. Remove the fuel hose clamps.
  1. Disconnect the upper and lower fuel filter hoses from both ends of the fuel filter. Plug the fuel hoses to prevent leakage and contamination.
  1. Remove the fuel filter from the fuel filter bracket (9A335).
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
