I hve an acer laptop and cant connect wireless to the sky router with cable its fine but wont work wireless
  • 849 Answers
It needs to install drivers of router.
Posted on Nov 27, 2008
MY LAPTOP HAS STOPPED RECIEVING WIRELESS SIGNAL FROM MY SKY ROUTER .LAPTOP WORKES FINE WITH YELLOW CABLE CONNECTED ANY IDEAS DERE BRADFORD
Are you sure you have not accidently turned off the WiFi connection on your laptop? On my laptop it's "function" plus F2. This turns on the wireless card inside your computer so it can receive signal from your router.
Mar 29, 2010 | Computers & Internet
How do I connect my sky broadband to a second laptop which I have just purhased
are you trying to connect wireless or cabled?
Wireless should be easy, just turn on the wireless device (if its built in) normally by pressing a Fn key and an F key marked with an antenna picture. Then connect to you Sky router after the wireless scan (the number and network key are printed on your router base)
You should just be able to plug an RJ45 network lead into your laptop and it should use DCHP to work (Plug and play).
Feb 13, 2010 | Acer Televison & Video
CANT GET MY LAPTOP TO CONNECT TO INTERNET
Are you able to change the SSID, create a new key, save then reboot the router? Then let the laptop find the new network. If this does not work, it may be time for a new router
Jul 09, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Mar 21, 2009 | Acer Computers & Internet
Losing Wireless Connectivety, when charging.
Try to plug in the power cable alone, do it without the battery and see if your wireless works.  If your wireless works without the battery, and works with the cable alone it may be a battery conductivity problem.
May 25, 2008 | Acer Aspire 5100 Notebook
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
My laptop cant find my wireless connection but finds other connections in range.I can only connect using ethernet cable from router.spoke to sky who said I need to contact acer as my laptop is not...
you might be blocked your SSID broadcast in your wireless router make it broadcat enabled then it will find your connection.
Your lap is ok and settings are well, b.coz it gets other signales. So just check your wireless AP settings.
Thanks
Iqbal
Apr 09, 2008 | Computers & Internet
Acer Aspire wont connect to internet wirelessly.
try to change position of your wireless router it will work.
Mar 17, 2008 | Acer Aspire 3000 Notebook
Wireless router
Has any security setting been enabled or configured before or after your son started connecting to it?
Jan 11, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
