Question about Akai LCT2715 27 in. LCD Television
AKAI LCT3201AD Yesterday I tried to turn my TVon and it did nothing except display the red standby light in the frontof the unit ( when the set turns on like it should the red light turns green).I unplugged the unit from the outlet, waited 10 seconds, and plugged itback into the outlet and the TV turned on. Today I tried to turn myunit on and nothing happened except the red standby light likeyesterday. The unplugging and plugging thing did not work either as itdid yesterday. I did notice that when I plug the TV in to the outlet Ican hear a high pitched sound coming from the back of the set, but whenI push the on/off button nothing happens except the red standby light.The TV is dead in the water.
  • 934 Answers
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Posted on Nov 27, 2008
Pioneer SX-20 Stuck on standby
It may be in protect mode because of damage to other components.
Mar 19, 2018 | Pioneer Audio Players & Recorders
Sony dab fc7 wont power on
Two thing here.
#one the internal fuse has blown unlikely as the standby light is powered.
Two the power supply unit or switch is faulty.
get some one electrical component with the unit unpluged open the case and check any internal fuses have not blown.
Two check capacities on the power board these are large cylindrical shaped objects. These can dry out and or exploded if faulty relatively cheap to replace.
Second check the power switch actual powers the unit again someone with a multi meter and electrical compertent.
It is probably worth replacing either a capacity or switch anything else may prove false economy
I have replaced power board on other units but to be honest unless the unit was very expensive I would buy new
Dec 06, 2013 | Audio Players & Recorders
When I turn my ps3 on, there is no audio/video. I don't think it's a software update problem, as I was playing my ps3 about two/three hours ago. I turn it off at the back, chill for a couple seconds, then...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
My PS3 won't turn on!
what model of the ps3 do you have
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai LCT2715 27 in. LCD Television Logo
295 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
