Question about HP Computers & Internet
I have an hp 2710p and I have purchased 2 batteries but the batteries will not take a charge
  • 849 Answers
Its mean your computer has a fault, consult a qualified technicia/authorized service center for assistance.
Posted on Nov 27, 2008
Dell vostro 3500 shows battery connected but not charging and intermittently shoes no battery detected
Instructions
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
http://www.aurabuy.com/cheap-9-cell-battery-for-dell-vostro-3400-3500-3700-7fj92-04d3c-paypal.html
Mar 28, 2013 | Dell Vostro 3500 Laptop Computer (Intel...
I have a laptop LENOVO (3 y.o). Now it seems that the Battery % is decreasing despit its being connect to the Power. Do i really need to Purchase a New Battery?
sounds like you do, if you just want to use the laptop on mains power you can just disconnect the battery completely and the laptop will work fine
Mar 09, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Battery not running
Possible that whoever replaced your battery sent you the defective one back. Note the serial and model numbers on the battery, then request another one. When you receive the replacement, do a full recharge. Most new batteries come already half charged. Even in this state, take time to fully charge it (between 4 and 8 hours depending on the type and model). Then try running it on battery power. If the charge holds more than 2 hours on a new battery, youre good; less than an hour new, its defective. If after all of this still not resolved, request the company honor their warranty (usually a limited one year with purchase).
Mar 01, 2009 | Dell Inspiron Desktop with Intel Core 2...
New battery will not fully charge
Hi, I have three possible answers!
A.
You're computer may not be capable of charging the full 12 cells. (Its only supposed to have 6). So you will only be able to use half the cells. In this case there is nothing you can do apart from just enjoy the 6 recognised cells.
B.
You computer has not fully recognised the 12 cells so you may need to install drivers from the HP website. Or alternately if you know how to and or have the original windows install disks. Then you can re-install windows and it will probably recognise the new battery properly.
!WARNING THIS WILL ERASE DATA - YOU NEED TO BACK UP YOUR STUFF!
C.
The third option is that the battery is duff, take it back to where you brought it and tell then the problem, they mey be able to help you or give you another battery.
Jan 04, 2009 | Computers & Internet
I have hp pavilion dv9000 and it was working for a few months and then once it wouldnt switch on. the power light flashes which indicates it needs charging but when i put the adapter in it says it is...
Don't quote me on this, but seems like it may be an issue with the battery. I would take it to a computer repair shop, or at least a RadioShack, and see if they will try the new battery (with laptop plugged in) before purchase.
Dec 05, 2008 | HP Computers & Internet
The battery won't charge so we bought a new battery, but when the battery got low we tried to chagre it and it won't charge, os we tried another charger but it seems as though we just can not charge a...
Hi Tracy!
Okay, there are a variety of reasons why this might happen but the best way to find out is to simply take out the battery but leave the AC adapter plugged in then turn on your computer.
-IF THE COMPUTER TURNS ON: then youre in luck. kinda. your new batter is a dud and you should get a free replacement from whomever you purchased it from.
-IF THE COMPUTER DOES NOT TURN ON: it is most likely the A/C cable. These can be bought online from the HP site or cheaper on Ebay. Although the AC cable is the most likely reason, please keep in mind it might also be a number of other not-quite-so-easy to fix problem.
Keep us updated!
-TJ
Nov 30, 2008 | HP Computers & Internet
I have a crappy HP pavillion dv6000 laptop, after working fine on shutdown last night, i turned on this morning and it would not boot up. the lights on the volume bar lit up, flashed, and went off...thats...
It's acting like the juice is drained in the battery. Are you sure it's charged? Do you have a spare battery you can swap out?
Some of them come with two. I actually have the same series laptop (a Pavilion dv6258se, 6000 series), and they can be a little flaky.
I also had an issue where my HP power cable (that connects the laptop to the wall outlet) was faulty, and needed to be replaced, because it stopped charging the battery. I ended up purchasing a generic replacement power cable on eBay.
Jul 24, 2008 | Computers & Internet
Laptop battery wot charge to 100%
Please help us help you.....
1. Brand of laptop
2. Model of laptop
Alot of laptop batteries decrease in charge value throughout use. If your laptop is an HP it has a battery restore program with the orginal software sent with your HP laptop. It takes an overnight commitment to let the program run but it usally restores the life of the laptop battery. Another solution would to be buy a new one off ebay.
Jul 01, 2008 | Computers & Internet
Acer Ferrari 4000. The computer won't charge the battery. We have a new charger and a new battery both of which have been checked. It was purchased 2 years ago.
based on your information, with new ac adapter and new battery the notebook will still not charge your battery this is a motherboard problem. replace motherboard
Jun 19, 2008 | Acer Computers & Internet
Computers & Internet Logo
53 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
