Question about Amana Dryers
Lg8219w2 Amana gas dryer. Igniter is glowing, flame kicks on for 2-3 seconds and then goes out. This repeats itself every 45-60 seconds.
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
Illeagle
  • 525 Answers
SOURCE: dryer wont heat
About all that is left to replace is the flame sensor mounted at 9o'clock on burner flame tube, but I would double check your airflow, This is CRUCIAL to the normal operation of the dryer.
Also, a lint filter with an invisible coating from fabric sheets can cause an airflow disruption, try running without clothes and the filter removed.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Posted on Sep 12, 2008
lester482529
  • 226 Answers
SOURCE: Amana LGA30AL Dryer - does not dry cloths
most times this is due to a lint backup some where in the shaft leading out of the house.ecpecialy ifit vents out verticaly.you can use a compressor with a blowgun in most cases to solve this.
Posted on Jun 04, 2009
SOURCE: I have an Amana gas dryerDLG330RAW that doesn't
I have, for the 2nd time in 2 years, replaced the gas valve coils on my Amana dryer. Usually, intermittent (inconsistent) heat or no heat is caused by bad gas valve coils. They are one of the most common parts to fail and cost between 35 and 40 dollars for a valve coil kit and are easy to replace yourself. Remove the front of the dryer (or the bottom front panel, in some cases) and locate the gas valve. It is near the front, in most cases. There is a plate, held with 2 bolts, holding the coils on top of the gas valve. Remove the bolts and the plate, disconnect the coil wires from each coil and slide the coils off. Then place the new coils on top, hook up the wires, replace the retainer plate, and you should be back in business. Take note of which coil sits on which part of the gas valve. On my dryer, one coil has a 2 prong connector, and the other has 3 prongs. This should make it easy to determine which is which.
Posted on Jun 04, 2010
Gas dryer does not heat igniter glows red gas valve clicks but no flame
Since the igniter glows i am wondering if within 1 minutes does it go off??or does the igniter just stay on??
If the igniter just stays on and doesnt go off the problem is going to the FLAME SENSOR
if the igniter goes off but no flame the problem will be the GAS VALVE COILS
GENE
Oct 12, 2011 | Dryers
I have a neptune mdg5500aww dryer, goes on, glowing igniter... but does not turn on the gas... what is wrong
Their are 2 possible things wrong;
1) Does the igniter just stay on or does it glow and go off usually within 1 minute?..if the igniter just stays on and never goes off the FLAME SENSOR will be the problem
2) if the igniter does glow then go off but no flame..the coils that open the gas valve are bad
The part numbers are;
FALME SENSOR 338906
GAS VALVE COILS 279834
The parts could be ordered from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE..OldTech2332
Aug 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have an Amana gas dryer that doesn't ignite.
The most common failure when the igniter glows yet DOES NOT GO OFF followed by the flame is a defective flame sersor
this is what the flame sensor looks likeoldtech2332_46.jpgIt is attached to the outside of the burner tube,
Their are basically 2 types of those,1 that attaches to right side of burner cone and 1 that attaches to left..to order correct one what ya need is the model number which is typically on a label on the inside of the door on the rim of the drum opening
Just to be sure before replacing it,is that what your experiencing..that the igniter glows yet does not go off? if yes that pretty much sums up what your experiencing go ahead replace that flame switch.
If igniter do go off but no flame the problem will be with the gas valve coils
GENE
Aug 23, 2011 | Amana Dryers
Model LG8219W2 On initial start up igniter turns on and flame is ok, after heats up and cycles the flame does not reignite,I can see the igniter glow red but flame does not return. the igniter contiues...
HI. This will essentially be an issue that concerns the gas valve coils. With that said, I will post below a complete burner assembly procedure that will help you isolate the culprit. I'm sure that the coils will fail the test, but to be safe, follow the procedure to confirm.
Gas valve/Burner testing procedure:
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Click Here to access a exploded diagram of the burner assembly. The affected coils will be labeled number 15 and 10. The actual coil and valve assembly will be labeled number 11 and the burner will be labeled number 9
Aug 22, 2010 | Amana NED7200TW Electric Dryer
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 | Dryers
Dryer wont heat
Thank you,
Dave E. (Illeagle)
Jun 23, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
