Question about Frigidaire PLEB30T9FC Electric Double Oven
TURNED THE OVEN TO "CLEAN" LAST NIGHT AND NOW THEY ARE FROZEN.... CANNOT GET THE DOORS TO OPEN AND THE DIALS ARE FROZEN AS IF THE OVEN THIKS IT IS IN CLEANING MODE... WE CANNOT FIND THE OWNERS MANUAL.... IT IS MODEL NUMBER PLEB 30T9 FC , FRIGIDAIRE CONVECTION DOUBLE OVEN... its thanksgiving help!
  • lillith36 Nov 30, 2008
    this was incorrect information towards the problem i presented.
    Sergeant:
    Champion:
  • 291 Answers
Set the range as if you are setting it to clean and after you hear it cycle into clean then cancel and it should unlock ,,,, please remember to click on rating / thanks
Posted on Nov 27, 2008
How do I get the door open on my oven?
Most newer ovens have a lock on them, and you probably haven't noticed it. look for a lock button. It will probably be electronic, not a mechanical button. Not sure what brand you have or how old it is.
Apr 25, 2015 | Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
F-10 code and continuous beeping
Your board is going bad
Aug 25, 2009 | Ovens
Oven door won't unlock after self clean
Try unplugging it. If that does not work, try to use a flat object like a butter knife, to move the latch (between handle, and top of stove.) Other than that... have a handy guy you know come look at it....
Jun 04, 2009 | Kenmore Ovens
Oven Door Locked After Cleaning
Go to electric panel. Turn off the oven breaker, open door, now turn breaker back on.
Jan 16, 2009 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Need help unlock oven after self cleaning jenn air jjw9527
The temperature setting must be set on "Cleaning" and the oven cooking dial to "Clean"; otherwise the door will not open and forcing will damage the mechanism. Also, before the door will open, the internal temperature must drop to a safe level and a red "cleaning" light must go off, after the temperature drops inside the oven.
Aug 23, 2008 | Jenn-Air Ovens
Oven door open
Turn the operating mode dial to self-clean, then manually hold in for about 20 seconds the light pin on the oven rim. The lock will eventually open after 20 or so seconds. Turn off the operating dial and the door will close.
Jan 12, 2008 | Ovens
try hitting self clean again give it a few seconds for the eoc to think the door is locking then hit stop/clear or cancel let me know if this helps if not i can call ge tech after holidays
Dec 28, 2007 | GE JKP15 Electric Single Oven
Oven works when it is open
sounds like the oven door switch got bent or misaligned
Dec 20, 2007 | Bosch HBL 5056 Electric Double Oven
Frigidaire PLEB30T9FC Electric Double Oven Logo
98 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
