Question about Panasonic KX-P1131 Matrix Printer
WHEN TRYING TO PRINT TO THE DOT MATRIX PRINTER NOTHING HAPPENS
IN PRINT MANAGER THE DOCUMENT APPEARS ON 2 LINES AND KEEPS SWITICHING FROM ONE TO THE OTHE OTHER. THE SECOND LINE SAYS SPOOLING AND KEEPS FLASHING ON AND OFF.
  • 446 Answers
It looks like it was hanging, reset the unit again and cancel all spooled file that you wish to print, even all the queued file, the file was somehow corrupted along its way
Posted on Nov 27, 2008
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
Apr 03, 2013 | Tally 6312 Matrix Printer
I need to print a .pdf document on a dot matrix printer. I get strange characters. Can you help me?
Hello
This error only appears, when
the printer is not selected as default printer and the print will go on other printer installed or the driver of the printer were not installed correctly.
Good luck
Dec 10, 2010 | Epson LQ-2180 Dot Matrix Printer
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
Difference between dot matrix printer and laser printer
1. Dot matrix as the name suggests prints in small dots. The print out u get in railway tickets. 2. Laser printers are very speedy and have clear and sharp printing. There is no comparison b/w a laser printer and dot matrix. If dot matrix is 1st GEnaration than laser is atleast 10 generations ahead
Aug 20, 2009 | Absolute Software ComputraceComplete for...
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
Unable to do a reverse line feed
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
TallyT2240 Dot Matrix only prints the middle part of the caracters
It sounds like you have one of two problems;
1) The ribbon cartrige it warn out or damaged, leading to no ink in a particular area.
More likely
2) The print head is damaged or warn out or is not connected correctly to the pritner. The print head may need to be reseated or if this does not fix the problem the print head may need to be replaced.
Oct 28, 2008 | TallyGenicom TallyT2240 Dot Matrix...
"Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
Printing problem with Star Sp200
Seems like a problem with the printer head...It is usual for matrix printers and it happens due to wear and tear..You will have to get the printing head to get replaced..
Oct 27, 2007 | Star Micronics SP 2000 Matrix Printer
Panasonic KX-P1131 Matrix Printer Logo
239 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
