Question about Dell 924 All-in-One InkJet Printer
How to clear carrier jam in Dell Photo All in One 944
Don't know how to clear carrier jam
  • 446 Answers
Simply open up your printer and see if there is any residual paper that get stuck, in some case if you can find some small miniature piece of sensor it might cause a erratic sensing that there is a presence of paper while there isnt, try to clear this or clean.
paper jamming indicator means there is some paper in the paper path, unless otherwise ou clear this up you cannnot print.
after you may need to power down or restart your printer once again
cheers
Posted on Nov 27, 2008
I have a printer dell 944 and I can,t print anything because of carrier is jam
remove all paper from printer look inside carrier with a flash light to see if something is obstructing paper flow
Jan 30, 2011 | Dell 944 All-In-One InkJet Printer
Carrier is jammed dell printer all in one 944
check and clean the paper carrier and if it continues change the cartridge.
Nov 13, 2009 | Dell 944 All-In-One InkJet Printer
Dell 944 carrier jam
THE CARRIER MAY HAVE A FINE PEACE OF PAPER STUCK IN THE FEEDER ROLLER OR IN THE ROLLER PANS, REMOVE EVERYTHING, GET A CAN OF AIR AND BLOW IT OUT GOOD AROUND WHERE THE PAPER FEED AND EXITS THE PRINTER, THE CARTRIDGE MAY MAYBE GETTING SNAGED ON THE PRINT HEAD ALSO. SHACK THE PRINTER UPSIDE DOWN TO GET ANY TYPE OF MATTERAIL IN THE MACHINE, IT CAN BE PAPER, PAPER CLIP, STAPLE, PENCIL, ERASER MATTERAIL,
INK BUILD UP ON THE ROLLERS, CHANGE THE TYPE OF PAPER YOU ARE USING, IT MIGHT BE CHEAP PAPER PRODUCTS, LABEL GUM STUCK INSIDE THE PRINTER HOUSING AND EVERY TIME YOU USE IT JAMS.
ROD
Feb 13, 2009 | Dell 944 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo All-in-One Printer 944 cartridge carrier malfunction
Nobody fixes ink-jet printers anymore.
If the old cart will go back in OK, it could be a bad cartridge.
Dec 28, 2008 | Dell 922 All-In-One InkJet Printer
Dell 944 printer
There are two reasons the printer may report a carriage jam - either the carriage is jammed, or the printer thinks the carriage is jammed be cause it does not receive any movement information when it commands the carriage to move. This latter case seems to be the problem you have, and is usually caused by a damaged or displaced encoder strip. You can see what the encoder strip looks like for a different printer here. If the encoder is damaged, unhooked from its supports or covered with ink it could cause the issues you are seeing. If the encoder is still in place you can try gently cleaning it, but I would suspect that most likely you will need to have the printer serviced.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jun 30, 2008 | Dell 962 Photo All-In-One InkJet Printer
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 944 All-in-One Printer - printhead carrier jam
I just found that one of the little feeder rollers (??) on the roller bar has jumped out and is sitting (still attached by its spring) on top of the roller bar. I reckon that's curtains for the printer. Am I right or is it repairable?
Nov 25, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
933 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
