Question about Empire GWT-25 Wall Mounted Panel Heater
Wall heater new 07, worked great all last season, turned on this
Year worked fine 4 days until gas co. added additional tank yesterday and now won't stay lit for very long. Relit 5-6 times over evening and got up in night 2x to relight. Stll out again in am. Was able to visually inspect in daylight (T-Day) no obvious issues- vent appears clear tanks look fine. Anything else to look at? Can't get tech help til tomorrow with holiday- do have back-up electric heat.........Thanks!
    Scholar:
    New Friend:
  • 70 Answers
There could be something stuck in the pilot assembly since you added a new tank to system. Check to make sure flame is hitting thermalcouple. Can you wait for a repair man to come and take pilot assembly out and clean. He will also replace thermalcouple. If you can't wait and you feel comfortable with taking pilot assembly out. Turn gas and electric off to unit then pull cover panel off. Pilot assembly is held in with two screws. Take tube off of gas valve and take off thermalcouple line off gas valve too. take out pilot assebly. Once you have it out take gas line off bottom of pilot assembly. There is a orfice in side make sure you can see through the orfice. You can also clean thermalcouple with a wire brush or sand papper. Reinstall pilot assembly make sure all fittings are tight. turn gas back on and light pilot. If everything looks good turn power on. Turn heat up run heater for a few minutes then turn heater down and let sit to see if it will stay on.
Posted on Nov 29, 2008
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven...
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Oct 17, 2013 | Wolf Range CHR-10-229-FT11 Kitchen Range
Rheem Fury Gardian 40 gal LP water heater pilot will not stay lit
1) Clean air intake (flame arrestor):located under combustion parts and look for broken glass from TRD
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
2) Troubleshoot by type of gas control, and link to AS Smith service manuals
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Add a comment with more information
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 24, 2012 | Water Heaters
Pilot light wont stay onfor outside pool heater. gas co made a service call & relit the pilot light, it went out again 4 days later.
Thank you for posting your question here on Fixya.com.
Has anyone replaced the pilot generator yet? A millivolt heater (one with a pilot light) requires about .75 volts from the generator to operate. As the generator ages it puts out less and less voltage and eventually gets to weak to even hold the pilot gas valve open. Replacing it with a new generator will usually fix the problem you describe.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 17, 2010 | Pool & Spa
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Beko SCG 7521 gas cooker flame won't stay lit in oven.Once you light the flame in the oven & hold in the oven button for the recommended 10 secs it cuts it's self off when you release the oven...
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself klass-a@hotmail.co.uk
Oct 08, 2009 | Ovens
Hard to start any time of the day for 1994 Nissan Quest XE.
turn your key on, DO NOT TOUCH THE GAS PEDAL and start, good luck. Pumping the pedal doesn't do a thing for fuel injection. In thre days of carburetors and you had control of your own property, Pumping did a couple of things. It set the choke and added more fuel. But that was yesterday and yesterday's gone.
Jun 30, 2009 | 1994 Nissan Quest
On demand water heater won't stay lit
It's the gas valve. This pretty common. The thermocouple produces a small amount of current from the heat and this current holds the safety valve open inside the gas valve. Sometimes the safety valve gets sticky and your symptoms describe it exactly. People are always frustrated by the time it is certain to be the valve. You need to replace the valve. No one is allowed to fix a gas valve - liability - gas etc. Replace the gas valve and your problem will be solved. I am a master plumber/gasfitter and I am confident that this will solve the problem. Been there - done that.
Jun 16, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Empire wall furnace won't stay lit after addional tank added.
Air in gas line? Bleed the gas line and try again. Make sure tanks are on.
Nov 27, 2008 | Empire GWT-25 Wall Mounted Panel Heater
Open Questions:
Heating & Cooling Logo
139 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
