Question about Uniden Lands Phones
The navigation button on all of our headsets re startint to not work. some won't go to the address book, some we are unable to chrck the caller id. it lights up, and that's about it. we have the Uniden TRU9485-4 5.8 GHz Digital Cordless Phone Answering System w
  • 2 more comments
  • survivor06 Nov 28, 2008
    the solution sent DID NOT fix our problem. We have 2 bases(TRU9480) and 3 handsets(TRU9480), the solution did not cause the navagation buttions to work properly. The phone will light up when the button is pressed, but it does not do what it's supposed to do, as far as function. ANy other suggestions/solutions?
    this is the 3rd solution suggested. how do I go back and see the other 2?
  • survivor06 Dec 01, 2008
    None of the posted solutions worked for us. What we ended up doing is removing the navigation button, and now the feature is working
  • 65 Answers
To reset, do the following:
Press and hold [phone symbol ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER’S MANUAL
If that doesn't work, you may have to get your handset repaired. Here is a site where you can order repair.
and here is the manual in case you need it.
Posted on Nov 28, 2008
    Sergeant:
  • 291 Answers
Resetting by removing all the connections and then refitting them all again should work out.but if that does not work then it is quite possible that this is a moisture problem on the main circuit board of the device.just take a hair dryer and blow hot air on the main board for few minutes.and then refit all the connections and check out it will work.also clean if any dirt seen on the board with a tissue paper.
    Genius:
  • 2,035 Answers
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Good luck..
Posted on Nov 27, 2008
  • Uniden Master
  • 19,396 Answers
Unplug all the sets from power and phone cable, this should reset the system.
  • Ginko
    Ginko Nov 27, 2008
    Try first resetting the system, by unplugging all cable, just to ensure that this is not a setting or a system problem.
    If the navigation button is starting to go because the button is faulty after a prolonged usage, then the only reasonable way to fix it is by buying a replacement handset.
  • Ginko
    Ginko Dec 02, 2008
    Glad to know you fixed, surely " removing the navigation button" is a brutal solution, and surely we cannot suggest you to break your phones.
    I told you it was a faulty button at start, then it is not true that "None of the posted solutions worked for us", on Fixya you need to read all solution.
    4 days ago I told you: "If the navigation button is starting to go because the button is faulty
    buying a replacement handset."
    Surely I could not suggest to break your phone keyboard.
    Probably the comment was lost in your email
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
How do I change the caller ID name on 3G phone?
If someone is calling you, the names are whatever phone number matches you contact information in your address book. Just edit it there. If you are calling someone else, it's their address book that determines the caller ID name
Jul 22, 2014 | Apple iPhone 3G
I have no idea what standby looks like; but I can't access the phonebook; I see the symbol, but nothing happens when i press it; I have successfully linked my cell and downloaded the phonebook from cell;...
A qualified person will have to remove the back (and circuit boards if necessary) to get to push buttons. Check for bits of plastic or something stuck between push button and circuit board. Check for corrosion on circuit board or missing /misaligned switch pieces.
Oct 29, 2013 | Uniden D3588-2 Corded / Cordless DECT 6.0...
How do I associate a picture to a caller. Each time I try I get an 'Emptry Entry' message
Go to the picture. Say use image and select the 'Photo caller id' or 'contact image' option and select the person in the address book. Thereby you can associate an image with anyone listed in the address book.
Aug 17, 2009 | Samsung SGH-G600 Cellular Phone
My wife has a Nokia 6650 and when people call the number is displayed but he name won't she is getting very upset and the book sucks.
Caller ID works by displaying the caller infomation that is sent. When you receive the caller ID, it first tries to pair it up with a name in the address book, and if nothing is found, it just displays the number.
If you want the contact's name to show, then you must save it exactly as the caller ID displays it. Most often, only 7 digits are put in, when it needs to be the full 10 digits.
Jun 29, 2009 | Nokia 6650 Cellular Phone
My address book always shows up empty, but the numbers are stored somwhere on the phone because the caller ID shows up with name, number, pic, everything. even if i save a number in the address book, it...
Are you sure another address book isn't hidden? You can view all apps to see if it shows up. If you click the menu button and show all or unhide. If that doesn't work try switching to another theme.
Mar 31, 2009 | RIM BlackBerry Pearl 8100
Caller ID - all calls come up as "unknown call"
call your mobile provider and have them assist you with this issue.
Jul 21, 2008 | Motorola Mobility RAZR V3
Caller id doesn't work
This service is provided from ur service provider so plz contact ur service provider. tell them that ur caller id is not working. reply me
Apr 21, 2008 | Samsung C417 Cellular Phone
Lands Phones Logo
291 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
