Question about Lexmark Office Equipment & Supplies
Need to change the ink cartridge on lexmark model #x2350
  • 446 Answers
1- Turn the printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
2- Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps 3- Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
4- Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
5- Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you’ve completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
6- Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
Posted on Nov 27, 2008
My Lexmark X2350 will not recognize a replacement ink cartridge
Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark and these type of cartridges often result to poor print quality and/or may cause damage to the printer itself. Reliability of these type of cartridges is very poor.
It is highly recommended to use genuine Lexmark cartridges for the most optimal output experience. Lexmark printers work best with genuine supplies.
Jan 29, 2012 | Lexmark X2350 All-In-One InkJet Printer
How do I change the ink cartridge?
Perhaps the Lexmark X2350 User's Guide will be able to help you. Just click on this link: http://www.lexmark.com/publications/pdfs/2007/2300/2300-en.pdf. Scroll to Maintaining the All-in-One, Page 52, for instructions on how to change/replace the ink cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Jun 29, 2010 | Lexmark X2350 All-In-One InkJet Printer
X2350 All-In-One InkJet Printer: How do I change the ink cartridge in a Lexmark x23...
Here's the User's Guide for your reference. Just click on this link: http://www.lexmark.com/publications/pdfs/2007/2300/2300-en.pdf . Scroll to Maintaining the All-in-One, Page 52, for instructions on how to change/replace the cartridges on the Lexmark X2350. In some cases, even when the printer is on and the cover open, the carrier doesn't position to the center. Unplug the printer from the power source. With the cover open, hold the solid white tape in the middle inside the printer. Other end of it is connected to the carrier. Slowly drag the carrier to the center loading position. Load the cartridges. Close the covers. Plug printer back to the power source. Hope this helps.
May 07, 2010 | Lexmark X2350 All-In-One InkJet Printer
I CANNOT LOCATE THE INK CARTRIDGE ON MY LEXMART X2350. WERE IN THE WORLD IS IT AND HOW DO I REPLACE IT?
I have a different model Lexmark, but it looks like the same basic printer. You have to pull the whole scan bed up while the machine is one, and the printer cartridges will settle to the middle position for easy access.
Mar 21, 2010 | Lexmark X2350 All-In-One InkJet Printer
Where is the ink cartridge on the lexmark x2350
open the cover while power is on. the cartridges will slide to the middle where you can reach them
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
Is there a black ink cartridge compatible with my X2350 all in one?
Nope, this printer uses lexmark one color cartridge, and the black color is generated combining the three inks in color cartridge.
This printer will not work on a black cartridge.
May 17, 2009 | Lexmark X2350 All-In-One InkJet Printer
Location of ink cartridge in my lexmark x2350
The cartridge is enclosed in the cartridge carrier.
Here is a link to the Setup Sheet that shows installation of the cartridge. This is a PDF file.
X2350 Setup
Here is also a link to the User guide where it is described better. (Words AND Pictures) :-)
X2350 User Guide
Nov 07, 2008 | Lexmark X2350 All-In-One InkJet Printer
Change ink cartridge now nothing works!
I had a similar Lexmark all-in-one before. It may be stuck because you may have replaced the cartridge when it was off. Try to unplug it from the power outlet for 5 minutes. Then, plug it back in. IT should work now.
Oct 21, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 Paper Feed Troubleshooting
Check to make sure there arent any stray paper fragments in teh paper path. Also try taking a pencil eraser to the paper pinch rollers GENTLY.
Mar 26, 2008 | Lexmark X2350 All-In-One InkJet Printer
189 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
