Question about Yamaha Audio Players & Recorders
I have a P-85 piano that I wish to connect to my HS-80Mmonitor. The only output for the piano is the headphone jacks which I expect is about 80 ohms impedance. The input impedence to the monitor is not known but I assume it is quite a bit higher than 80 ohms. I believe that an impedance mismatch may cause a deterioration of sound quality. Specifically, the bass response is higher than I like when the monitor is used. Also the quality of the piano's tone suffers. Is there an external matching unit available?
    Novelist:
  • 189 Answers
Generally speaking of course, you would never direct the signal from an amplified output into a line level input, however with headphones the level of amplification required is so small that the signal will typically be even less what a line level input is expecting. So do you want to headphone output signal further?
Basically, if you connect a headphone output signal to a several thousand ohm line level input it will behave pretty much like a line level signal.
Therefore, I would try it as is first to see if your results are acceptable. The output level should range somewhere within what a line level range should be although you might have to turn the volume up more than you would have to if it were a line level out.
Just start with the volumes all the way down, then turn your monitor levels somewhere in the middle and then turn up the keyboard level and see how good the sound is.
You may be perfectly happy with the results, otherwise you could try a headphone amp, but be careful with the volumes
Here's a good article on this topic which should address any concerns:
http://www.sweetwater.com/insync/techtip.php?find=2000-10-26
Cheers,
bd.
Posted on Nov 27, 2008
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
Headphone jack is too big for my headphones
Get a
Universal 1/8" to 1/4" Headphone Adapter
Mar 21, 2013 | Casio Px700 Digital Piano
I cant connect regular headphones to the casio AP620 piano, it seems to have a bigger connection on the piano. Does anyone knows what it is?
A headphone jack converter is available from internet or local electronics store from as little as 99p plug your 2.5mm jack in one end and the other into the piano which will be the 3.5mm or bigger.
Hope this helps.
Sep 22, 2012 | Casio Celviano AP-620 88-Key Digital Piano...
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
I just want to use my old tascam 414 as a mixer so i can run 2 pianos and my computer through my 2 monitors - need help in hooking everything up
I would connect the 2 pianos to 1-2 and 3-4 (assuming you want to use the stereo outputs on the pianos.)
The computer I would connect to the stereo input named 5-6. You will need a 1/4" stereo jack here. Just like the one you find on old headphones.
You could also have the pianos in mono, and use channels 1 and 2, and then connect the computer to 3-4.
Connect your monitor speakers to L-R out.
See page 5 in the manual for a diagram: http://www.accessguitar.com/inventory/tascam/porta_414mkii_manual.pdf
Your computer goes where it says "effects" on the diagram.
Hope that helps!
Mar 06, 2011 | Tascam Starter Pack for 4-Track Cassette...
I have a Roland FP 1 digital piano, serial #AL21141N. It has gradually quit putting out sound through the speakers. At the onset of the problem, I could fit it by jiggling the 1/4" speaker plugs,...
I first would suspect the switches on the eadphone jack. Normally these cut off the speakers when headphones are plugged in. These jacks and the switches are really weak, poorly made, and easily broken, especially if headphone cord gets yanked.
Jan 14, 2011 | Roland Digital Piano FP4 Black With Stand...
I need to install a standard 1/4 phone jack in series with the 2 headphone jacks that are on the left front of my Yamaha P 70 electronic piano. Where can I get a schematic diagram, and a disassembly or...
What you are requesting will not work as you expect. The easiest way to achieve what you seek is to utilize what is called a Direct Box. This is essentially an external transformer that isolates the keyboard from any attached equipment (to eliminate grounding hum) and will allow you to conenct an XLR (low impedance) cable to the keyboard. I assume that you wish to attach the keyboard to some type of sound system which is likely to have standard XLR Mic inputs.
Update this with any additional questions that you have. Please note that using the direct box (about $20-$40) will be both the easiest solution as well as prevent the need to modify the keyboard.
Dan
Oct 18, 2010 | Yamaha Full-Size Keyboard
Good morning! I wish to plug our television into the LBT-ZX6 stereo, but the TV's output uses an optical audio cable. Is there an adapter of any sort that could convert the optical cable into the stereo...
You may be able to avoid messing with the optical output completely, if the TV has a headphone output, in which case, a phono-3.5mm jack adaptor will sort you out nicely.
If it has to be optical, I expect you can buy adaptors for this aswell, but I'd expect it to be more expensive.
Most local electronics stores will sell these. Radioshack is a good example. Also, you could look around on the internet.
Jan 25, 2010 | Sony LBT-ZX6 Shelf System
Marshall MG100HDFX 100-Watt Amplifier Head. The head phone jack works but speaker output is dead. Hooked it to speakers with another amp input and after word it stopped working. Can't see any overheated...
You'll have to take it in to get it repaired. From what you described it sounds like you blew the output stage out. You can't run from your speaker output jack into the input jack of another amp. You should go out of the recording out, line out, effects out or in the least case your headphone out. What happens usually is your output transformer short circuits due to a mismatch of impedances. It sounds like you still have a transformer though so you might have gotten lucky. You will need to take it in though. Sorry.
Nov 26, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
90 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
