Question about Hitachi P42H401 42 in. Plasma HDTV
Picture comes on then freezes
Picture comes on for about 15 secs. then freezes, then starts again then freezes. i checked all connections, didn't help. unit is only 1year old.
  • Anonymous Mar 28, 2009
    periodically the picture will freeze and sound will freeze for a few seconds. It doesn't always happen, but when it does it will happen over and over until I have to change to another channel. I have a cable box, but it has been changed again and again. Does anyone know if this is a problem with this model Hitachi?
    Problem Solver:
  • 22 Answers
Do you have sattillite or cable and what kind of recv do you have
Posted on Dec 03, 2008
Samsung TV no sound no picture backlight on and off
Check voltage at the power board. After 120 volts enter the TV, there is fuse then a small high voltage transformer, then a 100 uf rated at 450 volts capacitor. There should be 390 volts DC at the capacitor. Without this 390 volts the TV will shut down.
Dec 28, 2017 | Samsung Televison & Video
Sometimes it freeze when i have open something
open your pc & remove the rams >>> clean ram pins with pencil eraser untill they gets shinny >>> clean ram slots with a small brush >>> return the ram to there location >>> try it now ... if the problem persists check the hard disc for bad sectors and the cpu for over heating ...
Mar 14, 2012 | Dell Inspiron 570 Desktop PC (I5707163PBK)
My philips lcd monitor 150S is failing me. I switch it on and then it shows and after few seconds the screen is black (meaning its off no picture) Then I off it and on again and then got picture for 2...
Check connections are good. Check pins in plug. Check with another monitor. Check with another cable.
If all tests are satisfactory then replace faulty monitor. End of life!
Jul 13, 2017 | Philips 150S (White) 15" LCD Monitor
I have 3 lights and want 1 light to come on for 15 sec and then off and another 1 to come on for 15 sec and then off and then the last light to come on for 15 sec and then off and start the process all...
Intermatic 70815CR
30 amp max, selectable voltage 120V 240V etc.
You want to control 3 separate circuits.
So you need a timer with minimum of 3 independent relays.
Each circuit has a different program.
So you need a 3-channel timer. Each channel is programmed separately to operate a different relay.
You want timer to operate in 15 second intervals. Most electronic timers have minimum 1 minute on-off, so you need electronic timer with pulse capability.
May 11, 2010 | Amperite Dayton Solid State Timer On Delay...
Acer monitor swtiches itseolf off in i9n about 15
After much ado and waiting for tech support from Acer, remembered that some years ago something similar happened with a printer so I downloaded a new driver from acer for the monitor onto another computer, copied it to cd and then with much fiddling installed this on the acer, as it was installing monitor started to flicker and finally lit up again normally. Now working perfectly! When tech support phones, will tell them!!!!!!
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
My gps freezes 20 secs after starting the only way to stop this is to flick to menu and back again, what can i do ???? thank-you. running on win ce 5.0 core arm 4.
if it's tomtom,garmin,mio,megalan or asus
reset the button with a pin
for tomtom
press the power button for 15 sec
May 04, 2009 | GPS
TV freezes for a short period of time.
First a couple of questions:
1) What is the make and model please?
2) When the picture freezes, is it like a snapshot photo? or does the screen blank?
This sounds like an interruption in the digital data stream. If the picture remains on the screen, the "new" frame information is not being received nor processed. This can be as simple as a bad cable connection or noise on the digital information data lines.
Check to see if there is any pattern to when this occurs. For example, does it happen more frequently after the set has been on for a while? Try cooling down the set to see if temp effects the behavior.
Please update this and we'll work to resolve it.
Mar 16, 2009 | Televison & Video
KDFE55A20 Sony
Check the connections that plug into the Block assembly. sounds like a connection issue.
Jun 15, 2008 | Televison & Video
The monitor turns off and on repeatedly.
Linux and UNIX wget command help --dns-cache=off, Turn off caching of DNS lookups. Normally, Wget remembers the addresses it looked up from DNS so it doesn't have to repeatedly.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Hitachi P42H401 42 in. Plasma HDTV Logo
292 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
