Question about Dell Smart Card USB (h0227) Keyboard
Keyboard freezes in a lab the keyboard freezes for no apparent reason. rebooting fixes this, but is a bad solution being that the computers are locked up. any ideas why? it happens when the computers have been sitting idle for awhile. thanks
  • Timothy  Lee
    Timothy Lee May 11, 2010
    Does it only happen ater you have typed anything or does it freeze shortly after booting.
    Problem Solver:
  • 11 Answers
You have two choices. Upgrade or find the proper driver for the keyboard, or don't allow your computer to go into sleep/hibernation when not in use. You can probably find the driver at Dell's support site. http://support.dell.com
Posted on Feb 14, 2010
SOURCE:
Samsung 700Z5A keyboard input errors
A computer keyboard is a vital component of the computer system. Without a properly working keyboard, your computer is essentially rendered ineffective. If the keyboard is frozen or not responsive, it is experiencing an error known as a "lock out" error. There are various reasons for this error, so you must undergo a process of elimination to figure out the root cause.
Make sure that your keyboard is properly connected to the computer system. Ensure the keyboard's plug is plugged into a USB port. A keyboard error will occur if the keyboard is not attached to the computer or if it is loosely plugged into a USB port. If this is the case, the keyboard will not be recognized and rendered useless. Press the "F8" button repeatedly as the computer boots up. This will take you to a menu in which "Reboot" is one of the options. Select the "Reboot" option. Rebooting your computer should clear up errors in the computer system that might cause your keyboard to lock out. Click the desktop's "Start" button. Right-click the "My Computer" icon and click "Properties." Click the "Hardware" tab and click the "Device Manager" button. Scroll through the "Device Manager" list and right-click on "Keyboards." Click "Properties," then click the "Driver" button. If the keyboard is classified "Disabled," click the "Enable" button to activate it. If this does not help, click "Roll Back Driver" to revert your keyboard driver to its last working state. Rolling back the driver should rectify keyboard errors. Restart your computer system to finalize the process. Hope this helps.
Dec 13, 2012 | Samsung Computers & Internet
Gateway SX2850-33: Both the wired keyboard and mouse lock up for no apparent reason sometimes after several hours. Reboot corrects the problem until next occurance.
are you sure the keyboard and mouse locking aren't a symptom of another problem? use your computer until it locks again, once it does restart the machine and when it loads press the windows key and the R key at the same time, in the run dialogue type eventvwr, look at the system and application events and look for red X's which are hard errors. then copy/paste the results here
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Aug 01, 2012 | Gateway SX2850-33 (PTGAZ02032) PC Desktop
My keyboard is locked how do i unlock it?
Maybe you keyboard is bad or your keyboard has been hijacked by a virus.
Make sure you keyboard is plugged in good on the back of the computer. If the end of your keyboard that plugs into the computer is Round and it plugs into the green port on the back of the computer you have a PS2 (serial) type of keyboard and you cannot unplug it and expect it to work if windows has already booted up. If you remove this type of keyboard connection, you have to Reboot your machine otherwise the keyboard is locked.
If the end of your keyboard that plugs into the computer is Flat, then you have a USB type of keyboard that goes into the computer's USB Port. This type of keyboard is Plug and Play so you don't have to reboot if you remove it. If you have this type maybe the USB Port you plugged it into does not work, so try plugging into another USB Port.
Try booting in Safe Mode and see if the keyboard performs.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
Apr 09, 2012 | Acer Computer Aspire AM3800-U3802A Desktop...
Keyboard locked
Apr 09, 2012 | Acer Aspire Z5700 PC Desktop
Please tell me how do i unlock my keyboard and mouse?
Sometimes,computer's keyboard and touchpad are locked for some apparent reasons. However, there is a key that you can press there to make it work again. Press FN + F7. If it does not work, click on the link and follow the additional troubleshooting steps that I have prepared. The complete troubleshooting that I prepared can be found in the link below:
http://www.fixya.com/support/r8113144-enable_touchpad_in_laptop
Thank you for using fixya.com.
Mar 31, 2011 | Logitech Wireless Access Duo Optical...
Acer 5100 keyboard and mouse will not work. No
Hello there, this is usually caused by one of three things.
Either something was just plugged in (usually USB) that is interfering that you can just unplug
The computer has locked up for another reason (more in a sec.)
Mainboard could possibly be bad / going bad =(
To test if the computer itself is locked up try plugging in an external USB mouse or keyboard to see if you can get that to work. If it does then that means the keyboard and mouse built in are failing, which again basically means the mainboard is failing.
Hopefully it will be that the computer is completely locked up so when you plug in an external usb mouse or whatever it won't respond. That's easiest to fix.
Please let me know
Thanks
Tim
Nov 06, 2009 | Acer NSK8458AN Keyboard
HP dv1000 Laptop Locks Up
It maybe bad sectors on hd but first Id defrag disk see if any improvement
Jan 23, 2009 | HP Pavilion dv1000 Notebook
Logitech cordless keyboard
you have your receiver close enough to your keyboard so the keyboard can pick up from it? try resetting the keyboard when the happens and checking your batteries, before resorting to reboot.
Jun 04, 2008 | Computers & Internet
Keyboards Beeps and Freezes
How much memory do you have install in your computer? This may not be the problem but can cause the problem you have if you don't have enough memory installed.
Hope this helps. Bud
Apr 20, 2008 | Kensington PilotBoard 64379
Acer Aspire 5100 Notebook Boots to Windows, but nothing works. No keyboard, no mouse, no usb or CD, no external monitor.
need computer keyboard drivers and/or layouts. Additional information and links to comptuer keyboard drivers and layouts.
Keyboard, Mouse, and other input related links Linking you to various locations on the internet about computer input devices.
Information about the AT and PS/2 port This port is commonly used for a computer keyboard. ... This port is used to accept input devices such as the Mouse and Keyboard.
A20 error Issue related to the keyboard and/or keyboard controller. Solution:. Ensure the keyboard is connected to the proper port on the back of the computer.
Additional information and help with installing computer hardware. PC computer keyboards PC computer motherboards PC computer mouse PC computer power supply PC computer memory ... CH000449, Installing a computer keyboard.
NTOSKRNL.EXE is missing or corrupt. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the
Read instructions/Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Acer Aspire 5100-5033 Notebook
Dell Smart Card USB (h0227) Keyboard Logo
73 people viewed this question
Clive
Clive
Alun Cox
