Question about Daewoo DV-6T834 DVD Player/VCR
My VHS-to-DVD Burned Disc used to work and now it doesn't
I copied a bunch of VHS footage to a blank Memorex DVD +R a few years back. It worked just fine for all this time but suddenly the disc won't play on this DAEWOO combo or any other DVD/PC player. When I load the disc in the DAEWOO combo player it just says it's EMPTY even though it played just fine before. My other burned DVD using this same combo player still works fine. Any suggestions?
  • richard lacuesta May 31, 2012
    I'm not sure that's the case because it doesn't say the disc is 'unreadable' it simply says 'DVD+R empty' when I put it in the DVD player. It's basically as if the disc is blank but it's definitely full. It worked just fine a few months ago. Not sure if this has happened to anyone.
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
Posted on May 31, 2012
SOURCE:
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
I have copied a vhs to dvd but dvd won't play on other dvd players
DVD+R is a Sony format, so it may not play in the more common -R format players. Are you finalizing the DVD's if not they will only play on the deck that recorded them
Jan 25, 2012 | NEC Televison & Video
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
Hi! I inserted a burned dvd r into my Mac but it's not reading it. The message You've inserted a blank CD pops out. I tried using a PC but it can't open it either, it says there's an error...
there are a few reasons why
1.) the formatting of the disk may be formatter for a PC and NOT a MAC
2.) after burning, this dvd was never "closed"
3.) You burned a coaster
good luck
Jun 06, 2011 | Computers & Internet
I don't know if my first REQUEST for Assistance was received, at any case, I REQUESTED to find WHY my GO.VIDEO COMBO Player is NOT READING any of my blank DVD DISC( SONY, IMATION, MEMOREX, DVD+R ), IT KEEP...
If there is nothing on the disc, it will read, "no disc". It will only read and/or identify discs with media loaded or burned onto it. Your unit is a player, not a DVD+R (recorder). Can record VHS, but not discs.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
Dvd 740b not reading blank discs to burn on
NO PC stated dang. laptop or desk?
internal DVD drive or external HP solds all 3.
NO OS stated. windows? Windows what>?????
no real DVD partnumber stated only the usless
front bezel number 740.
if yours is marked 2001,, its going to be a big problem. 9 years past HP support.
and all old drive are weak now or scratched optics.
and drives that old were even full of bugs then
(we an link you to 10,000 pages showing that)
why not upgrade it.?
get a new drive and new fresher OS.
windows 10
and a nice new blu-ray burner.
and move on.
or if this rig (PC)
is 2001 why not go to GOODWILL
and buy a 2010 PC< for like $25
and i bet it works 10x better.
Mar 18, 2017 | HP dvd740i DVD±RW Dual Layer Burner
JVC SR-DVM600 Dubbing from HDD to DVD Problem
Have you tried using a different brand disc. When I first purchased my DVM-600 it would not record on Memorex discs. I purchased TDK -R discs and all is fine. In the old-school analog world, all specific format tapes were computable to all machines. In other words, a VHS tape recorded in your VHS recorder will play back in my machine and every other VHS machine. Because the DVD format has so many formats and standards, compatability issues are quite common.
May 07, 2009 | JVC SR-DVM600
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Jan 15, 2008 | Panasonic (DMR-ES45VS)
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Daewoo DV-6T834 DVD Player/VCR Logo
155 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
