Question about Kirby Ultimate G Bagged Upright Vacuum
How do you install the belt on the kirby vacuum?
  • unconvention Nov 29, 2008
    Can't figure out how to put a new belt on.
  • Anonymous Jan 15, 2009
    Kirby Sentra Vacuum Cleaner - the belt came off how do I put it back on?
  • 446 Answers
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. how do you install the belt on the kirby vacuum - kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldsthow do you install the belt on the kirby vacuum - kirby-oldstyle2a.jpgi kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasinhow do you install the belt on the kirby vacuum - kirby-oldstyle3.jpgn the rear. Pull the roller plate up slighhow do you install the belt on the kirby vacuum - kirby-oldstyle3a.jpgimg src="http://i.fixya.net/uploads/images/kirby-oldstyle3.jpg" alt="kirby-oldstyle3.jpg" class="h_mi" /> kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the rollhow do you install the belt on the kirby vacuum - kirby-oldstyle4.jpg of the roller. If you need to replace thehow do you install the belt on the kirby vacuum - kirby-oldstyle4a.jpgthe way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirhow do you install the belt on the kirby vacuum - kirby-oldstyle4.jpgas a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latchow do you install the belt on the kirby vacuum - kirby-oldstyle2.jpguum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Posted on Nov 27, 2008
VacuumRepair
  • 438 Answers
SOURCE: i need to know how to put my belt back on my kirby
Greetings from GoVacuum,
Here's a very informative video that we've recorded explaining in detail how to correctly install the belt on your Kirby Generation vacuum cleaner. I hope this will help you.
Kirby Belt Change Video;
If this video was helpful, please be sure to rate this Solution by clicking on the 4 Thumbs Up icons in the top right hand corner of the page. If you have any questions, please feel free to email me, I'm more then happy to answer any questions you may have.
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
  • 10 Answers
SOURCE: How to put a Kirby Vacuum belt back on
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Posted on Jan 27, 2010
b0sslady2001
  • 357 Answers
SOURCE: kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Posted on Oct 25, 2007
SOURCE: Kirby Sentra vacuum burning belts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=565459
Generic problem for all Vacuums
posted by campoclan on May 02, 2008
Have had Kirby vacuum for a couple of years since I've had it I burn at least two belts in two months. I keep roller clean, what is the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the problems that people have is that they feel they have to have the vacuum head all the way to the floor and that makes the belt work that much harder. The key to the best cleaning is to raise the height adjustment all the way to the top and once it’s there then drop it down one notch or setting @ a time until you here the tone change. Then try it to see if the vacuum if picking up well if not drop it down one more notch and that should be the setting it is supposed to be for your type of carpet. And remember to use the genuine Kirby belts instead of the Kirby replacements, they will work better. And your suggestion that to keep the brushroll clean and free spinning on each end and also keep the bottom plate clean of dirt and grease because if there is a build up it will move slower and leave black marks on the carpet. I hope this will help and if not contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 27, 2008
  • 52 Answers
SOURCE: How do we change the belt on our Kirby Vacuum Cleaner
Here is a link to a video explaining how to change the belt on a Kirby vacuum. It is at the bottom of the page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
Posted on Jun 16, 2010
Change belt on Kirby heritage vacuum
It is the same as installing a Kirby Generation belt.
Here is a walk through:
Install Kirby belt and nozzle
800-775-6586
GpodVac com
Sep 15, 2014 | Kirby Vacuum Fan Heritage G3 G4 G5 Ult G...
I need to know how to put my belt back on my kirby 2000 G6 vacuum belt
Chris Jones
GoVacuum.com
Mar 02, 2010 | Kirby G6 Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How to put on a kirby vacuum belt
The emblem on the front of the Kirby vacuum controls the installation of the belt. Rotate this emblem. ( I do not remember which direction it rotates). This relieves the tension on the belt. Replace the belt and rotate the emblem back to lock it in.
Please rate this solution
Jul 31, 2008 | Kirby Vacuums
How to change kirby vacuum belt?
Greetings,
Here's a video where we show you how to replace the suction fan on a Kirby Generation vacuum cleaner (also known as the impeller blade). I hope this video helps;Chris Jones
GoVacuum.com
Jul 20, 2008 | Vacuums
REPLACING BELT KIRBY CLASSIC III
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=806061
Posted by JETALBOT on July 19, 2008
I CAN'T REPLACE THE BELT ON THE CLASSIC III (KIRBY). CAN YOU HELP ME? ELAINE
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Mail To: Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jul 19, 2008 | Kirby Heritage II Vacuum
How do you change the belt on the kirby sentria
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=722171
Posted by erikh_85 on Jun 30, 2008
How do you change the belt on the Kirby sentria
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. 1st, you need to see if the head of the Kirby comes off, and if does then dial the belt off from the Kirby spoon/hook counter clock wise and then remove the bell housing off of the vacuum. Then remove the bottom plate using the 2 levers and then lift out the brushroll, remove the old belt and then slide the new Genuine Kirby belt onto the vacuum and then re-install the brushroll with the screw heads facing towards the carpet. Then using the dial spoon/ hook then dial the belt on to the fan pulley dialing counter clockwise and the belt should be on the vacuum then id your bell housing is removable then re-install the bell housing and lock it down. The plug it in and test the vac to see if it is picking up. If you have questions please feel free to contact you local vacuum cleaner dealer in your area or contact the Kirby cust serv.
Mail To:
Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
Installing belt on G7D Kirby vacum
For belt replacement instructions watch video
http://www.goodvac.com/
Good Luck,
Rocky
May 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do you replace the belt on the Kirby, Model No D50, Serial No. A442867
This is an older Kirby vacuum and the front brushroll section of the vacuum and the front brushroll section will come off, 1st you have to remove the front cover (the Kirby Emblem) and under that there is a Kirby spoon or hook and you need to dial off the belt off the belt shaft, once that has been done remove the bottom plate and un-install the Kirby brushroll, check to see if the brushroll spins freely, if it does go onto the next step, if not clean off the hair and thread from either end and then re-check the brushroll, if it still binds up then replace the brushroll and belt with Genuine Kirby belt and brush. Then use the dial to place the belt onto the Kirby spoon / hook. Once the belt is on the hook, install the bottom planter and place then housing of the Kirby on the vacuum and use the lever on the top to secure the fan housing dial the belt onto the pulley and you should be good to go.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Apr 21, 2008 | Vacuums
I can't get the new belt on my kirby
I can't get the new belt on my Kirby
The Kirby Vacuum has a removable head and bottom plate and the belt is hooked on by a hook inside of the Kirby head of the vacuum. You need to slide the belt onto the Kirby brushroll to the center and the dial in front of the Kirby vacuum does rotate to the right – so @ this time you would dial the belt clockwise and the inside hook will pickup the inside belt and continue turning the dial / hook until it stops – look inside to see if the belt in on the fan shaft – if it is then install the bottom plate back on the vacuum and then install the head back on the Kirby or if it is newer the head is already on the motor assm.
Plug in the vacuum and if the belt stays on and the brushroll is tuning you have done it right – if not reverse the situation, unplug the vacuum and start over with the procedure. The hook will dial the belt onto the fan pulley if done correctly. Example: try to turn the dial on the front of the vacuum to see hoe it works and the way the dial will turn so that the procedure will be easier. The dial does turn hard when dialing the belt onto the pulley.
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
1,864 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
