Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Picture size how can I shink the picture to fit in screen? Picture is in Dot by Dot but is slightly oversize. Picture in guide fit's fine , leads me to belive cable is ok , but TV needs to be formatted.
  • 1 more comment
  • swedgbury Dec 03, 2008
    unable to find Digital Setup in menu screen. Where is it located ??
  • swedgbury Dec 05, 2008
    There is no Digital setup tab on menu.
  • orourke_r Dec 09, 2008
    my television picture is totally out of proportion!!
  • 558 Answers
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Digital Setup
This setting allows you to set the image of Digital
broadcasting.
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Manual
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
Auto.
All broadcasts will be converted
and displayed in the 1080i
format.
Posted on Nov 28, 2008
  • Scott Hill
    Scott Hill Dec 03, 2008
    press menu then move the cursor left or right to the digital setup tab then press ok or enter, it may be off screen but go right and it should appear.
Picture doesn't fit the screen
Its a function of the source and the tv picture settings. Go to the source (direct tv, cable, co-ax?) menu , settings and look for screen display sizes.
Your remote has a red dot "wide" button which will also have a screen size effect. You can cycle through the formats
For further info why not read/print out the manual?
http://store.vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
Sharp view area
This has something to do with the setting. Try resetting through remote and see.
Aug 21, 2012 | Televison & Video
Picture size shink frem top in samsung plano
by a white line on the screen - problem faulty Vertical IC and sometimes the 24V missing for the IC too and some Elkos by the IC
Jul 23, 2011 | Samsung TXN3271HF 32" TV
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
Good evening, I've gone through the manual and I can't get my TV to show 100hz (always 50hz), also on some channels I cannot get the picture to fit the screen (it's 32''). Any help would be greatly...
Well, first the 100Hz issue. Your TV will display a descriptor or the signal it is receiving, not a descriptor of the picture you are watching. Your TV panel has a native resolution and frequency. In your case, that frequency is 100Hz. Everything, like it or not, must be converted to 100Hz for the TV to work. In your manual, you are simply adjusting setting which smooth the picture and make it flow better than it would at 50Hz. This feature is slight of hand and is probably working just fine. As for the picture fitting the screen; HD programs fill the screen of HD channels.... SD (Standard Definition) programs use black bars on each side when on HD channels. You can use any available wide or picture size feature your TV may have to stretch the picture. You may be unable to stretch the picture, due to restrictions (some TVs will not resize HD formats).
Mar 15, 2010 | Televison & Video
PIcture does not fit on TV
TV must be set to zoom, take the zoom setting off
Mar 06, 2010 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Full tv screen is not being diplayed horzontally.
First thing to check is the picture size. You can view many program formats in a variety of picture sizes
  1. Natural
  2. TheaterWide 1
  3. TheaterWide 2
  4. TheaterWide 3
  5. Full
  6. 4:3 HD
  7. Native
  8. Dot by Dot.
The format of the image will vary depending on the format of the signal you are currently watching from you cable or satellite provider. Select the picture size that displays the current program the way that looks best to you.
To select the picture size using the remote control:
  1. Press I on the remote control.
  2. While the Picture Size screen is open, you can do one of the following to select your desired picture size:
• Repeatedly press I.
• Press the corresponding Number button (0–6) while the Picture Size screen is open.
• Press B or b while the Picture Size screen is open.
To select the picture size using the menus:
  1. Select Picture Size in the Theater Settings menu.
  2. Press C or c to select the desired picture size setting.
  3. Highlight Done and press T.
Some of the picture sizes may not be available depending on the receiving signal format from your cable or satellite provider (those will be “grayed out” in the Picture Size screen).
Second thing to check is the Native Mode which restores the size of the picture by the 3-5% that is generally lost during the normal over scanning that occurs on traditional sets. It also avoids unnecessary scaling of 1920 x 1080 HD signals. I hope this helps and good luck!
Feb 24, 2010 | Toshiba REGZA 52RV530U LCD TV
TV picture aspect ratio
No. Aspect Ratio is same for UAE and India, and also the broadcast System.
Most Cable TV operators in India broadcast the signal 'slightly oversized, and so the viewer gets the Scrolling at the bottom and top of the screen cut-off.
Nov 29, 2008 | Panasonic TC-25P22R 25" TV
Picture size
Please read page 39 or in your manual page 38
Nov 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
685 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
