Question about NetGear WGT624 Wireless Router
Router loses connection
About every twenty minutes or so for the past two years I have had to walk upstairs and reset the router. I did not have this problem when I had DSL, but when I switched to Bright House (cable modem), thats when the problem began. I tried setting up the router several different ways but I still have the problem. I am sure there is some sort of simple solution, but until I know what that is I feel like a real idiot and just keep going back upstairs into my roomates room and pressing the little reset button on the back of it. Can anyone help me please?
    President:
  • 2,961 Answers
Somebody else on this site had similair troubles and it was down to the fact that the cable company change the IP address of the connection frequently. Now, if this is the case your router will lose connection if it's a seperate modem as it will lose the modem IP address. I would contact your provider for a solution if this is the case.
Posted on Jan 12, 2007
SOURCE:
Lose nettalk connection from router after on phone for twenty minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 28, 2013 | netTALK DUO Wi-Fi VOIP Internet Phone...
After over a year of good use, the past 2 weeks have seen the router repeatedly lose the internet connection after a minute or so of use. It reboots ok initially but then loses the connection again.
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
Oct 11, 2010 | Linksys Wireless-G WRT54G Router
Laptop is upstairs, computer and router downstairs. Keep losing connection upstairs. shaw suggests I ask you to change settings. I have model WRT 160NV3 , Cisco.
You will need to check the wireless settings of the
router
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
Click here for step by step instructions
Jan 16, 2010 | Linksys WRT160N Wireless Router
I keep losing my wireless connection inside my home. My modem is in the basement and I want to use my laptop upstairs. I use an N router and have cable internet. My house is also wired with Cat 5 wiring...
Well , the connection upstairs depends on the capabilities of the router that how much coverage it can give for the wireless clients associated.
Since , it is a N-router so try upgrading the drivers for it , the technical term will be firmware.Upgrade the firmware of the router to the latest one and you might have your issue resolved.
Nov 24, 2009 | Computers & Internet
Connecting to a lapto
Hi rgf47331,
When you move upstairs there is a solid wall in between that interfears with the signals.The only thing you can try is calling up belikin and asking them to check your settings on the router and see if changing the mode or channel helps. i wont recommend you do that on your own as you may end losing the connection altogether.
I hope this helped
Keshey
Feb 16, 2009 | Belkin (F5D7230-4) Router (587009)
D-Link DIR-628 router, i've lost internet connection to the PC!
You would be best to buy a wireless router with a built in modem, this would be much easier for you to setup and manage
Nov 16, 2008 | D-Link AirPlus DI-524 Wireless Router
I keep losing my signal intermittently on my Belkin MIMO plus wireless router it constantly goes up and down from 1.0 Mbps to 54.0 Mbps interferring with my connection. The router is connected to my...
your gonna need the belkin router amplifier for that if its too far away from the router its gonna loose signal and cause you to intermittinly loose signal and connection ./... you could also contact belkin support at www.belkin.com/support
Jul 19, 2008 | Belkin Computers & Internet
Can't reconnect - NetGear RangeMax WPN824 Wireless Router
Try changing the channels of the router to 1,9,or 11. this may help minimize wireless interference.
Mar 27, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear WGT624 Wireless Router Logo
117 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
