Question about HP Photosmart 2610xi All-In-One InkJet Printer
Paper Jams I have a HP Photosmart 2610xi all in one printer It stopped feeding paper , every time it trys to feed it pulls to the left and jams from the tray. I have tryed to clean the rollers with water , did not work ,I tryed with alcohol and that did not work. It jams every time , and the same way.
  • berander Feb 15, 2009
    Same problem here. Paper feeding starts out ok, but just when the paper has turned around and is on it's way out from the printer there's just a triangular tip pointing out and paper jam error.
    I've tried lots of times w. different amounts of paper, quality a.s.o but to no avail...
    Will try looking for obstruction though and will report eventual success.
  • Anonymous Mar 07, 2009
    The paper is jammed and I can"t pull the paper out. Is there a way to open the copier beyond lifting the top part up?
  • 446 Answers
There must be on obstruction in the paper path, either there is a piece of paper or caked or hardened ink along its way, the indicator that it pulls from the other side suggest that it is touching somethng try t open it up again and see, and see the paper guide matches the size of your paper say letter size in this way the feeding will not be crooked
cheers
Posted on Nov 27, 2008
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Paper jam door - I cannot open this no my HP 8250.
Turn off the printer, then unplug it from the power source. Clear the
printer of any paper that may be obstructing the paper path. Remove the rearaccess door. Gently remove the jammed paper from the printer, then replace therear access door.
Remove the rear access door to clear paper jams.If you cannot remove all jammed paper from the rear area of the printer, tryremoving paper jammed in the middle of the printer by opening the paper jamdoor located inside the top cover.
Open the paper jam door to clear paper jams in the middle of the printer.Plug the printer back in and turn it on.
In case of any doubt go to the following link and act accordingly
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00386753&lc=en&dlc=tr&cc=us&product=443024
Sep 25, 2011 | HP Photosmart 8250 InkJet Printer
As the paper starts to feed through, it jams on the left side, as if the left side roller is feeding the paper in faster than the right side
Take a soft cloth (not paper towel) moistened with alcohol and clean off the rollers that pickup the paper. Make sure you clean the entire roller. Chances are that there is paper dust on one or more rollers and they're slipping, causing the jam.
Feb 26, 2011 | HP Photosmart 2610 All-In-One InkJet...
How to correct paper jam in HP Photosmart 3110 all in one
Here is a link on how to clear all the paper jams that can happen on your HP printer. Also, here is another link on how to clear the paper feed rollers on your printer.
And here is the User Guide for HP Photosmart 3110 for any reference.
Dec 14, 2010 | HP Photosmart 3110 All-In-One InkJet...
Hp 2610 paper jams on print command. Paper pulls sideways.
find the paper feed rollers and clean them. they get slick and one side will catch quicker and pull the paper side ways.
Aug 12, 2010 | HP Photosmart 2610 All-In-One InkJet...
False paper jams and multi sheet feeds
multi feeds and jams are mostly caused by static electricity in the paper. ALWAYS fan paper top and bottom to remove static and "aerate" the paper before putting in prnter. Doing that will reduce the problems you are experiencing.
Please rate my help++++Thanks for using FIXYA
Oct 22, 2009 | HP Photosmart 8150 InkJet Printer
HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 03, 2009 | HP Photosmart C6280 Printer
Paper jams in HP Photosmart C7180 All-in-one
Underneath paper tray spring had broken and the drawer wasnt going right into position, needed to move lugs underneath which allowed tray into proper position and now all is well!!
Apr 09, 2009 | HP Photosmart C7180 All-In-One InkJet...
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
HP Photosmart 2610xi All-In-One InkJet Printer Logo
197 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
