Question about Linksys Wireless-G WRT54G Router
Linksys wireless G CD will not install
Once the installation CD instructs me to plug in the power cord and I plug up the installation hangs up with a message that my router connection doesn't seem to be connected properly.
  • Michinoka Nov 27, 2008
    I have the same problem....
  • captshew Nov 29, 2008
    Thanks joed911 you are a genius! You solved my problem!! After I tried your suggestion without the cd, everything came up roses, so I threw the cd in the trash burner!
  • Linksys Master
  • 4,338 Answers
HA!
Posted on Nov 29, 2008
  • Linksys Master
  • 4,338 Answers
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed.
then:
Connect the Cat5 cable from the modem to the WAN port on the router. Then connect a Cat5 cable from any port on the router to your PC's network port.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 28, 2008
What to do when security light is orange?
Reboot
  • The most basic way to attempt to fix a router problem is to reboot the device. This is accomplished by unplugging the powericon1.png cord, waiting for a minute and then plugging the power connector back in. If the orange light continues to blink, you will have to update its firmware.
Download New Firmware
  • Even though the wireless router is malfunctioning, downloading new firmware is possible by disconnecting the malfunctioning Linksys device from the Internet connection in the wall, then using that jack to plug your machine directly to the Internet. If this is not possible, use another computericon1.png that can connect to the Internet. You can download a firmware update directly from Linksys (see Resources).
Install New Firmware
  • Once you have the firmware update available on the computer affected by the malfunctioning router, open the file and follow the instructions to upgrade the devices firmware.
May 11, 2014 | Linksys Wireless-N WRT150N Router
I need a driver for linksys wrt54gs2 v1 wireless router
Hi mariervin
linksys wrt54gs2 v1 wireless router drivers can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Aug 07, 2012 | Linksys WRT54G2 Wireless Router
After installing cd the window that pops up has no tabs to click
You do not need to install the CD that comes with the router. After plugging in the router, simply connect to the wireless network by clicking Start>Connect To. Click Linksys. Click Connect
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
Router not connecting
The problem here is that the WRT54GS is an old model, so naturally the installation CD is also old. This is especially a problem if you are running Vista. I ran into the same problem when I was installing my wireless card; my computer would detect it on boot up, but when I installed the drivers from the CD, it said the card wasn't plugged in.
The solution would be to download the lastest installation and driver files from the LinkSys website and use those instead of the installation CD that came with it. You may have to hunt for it, as some companies would rather push new products than update older ones, but since the router is still on the market, they should have the updated drivers and installation files.
Feb 11, 2009 | Linksys Wireless-G WRT54GS Router...
Installation is stuck at 30%
hi
may be the installation software is not working,what you need to do is take the cd out from the computer and just plugg the wireless adapter,when you plug in the wireless adapter it will tell you to insert the cd that came with the usb card so that the software can be installed,once you see this message insert the cd and then follow the setup screen(imp thing:incase you see the screen of the linkys installation donot follow that,follow the windows software setup screen) this will install the software and i am sure the software will get installed if the software has totally gone bad then here is a link you can donwnload the software from website and then try the installation
link for linksys wusb54gsc for :
http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1154470123093&pagename=Linksys%2FCommon%2FVisitorWrapper
vedhick
Jan 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Dec 16, 2008 | Computers & Internet
Cannot finish installing
It means you have to plug in your computer to the router through a ethernet cord. Most computers have one, and on the back of thats router has 4 ehternet female ports. Plug it in, and run it again.
Dec 02, 2008 | Linksys Wireless-G WRT54G Router
Linksys WPC54GS wireless adapter installation issue
There's a possibility that the adapter is defective. However, you may still try the following:
1. Make sure to uninstall the software if you still have it installed. Remove it from the Programs list or under Add/Remove Programs.
2. Check Device Manager and make sure adapter is not under Network Adapters nor Other Devices. It might be called Network Controller if driver is not installed correctly.
3. Unplug card, shutdown computer and when PC is powered off, plug card back and restart computer.You may insert the CD on this process, but do not run/continue the CD setup wizard.
4. When computer is back on, you should get a Found New Hardware bubble message or wizard.
Just finish the wizard and tell me how it went. Goodluck!
Jul 08, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
"WPC54G is not installed"
Those install programs that Linksys uses are terrible. This happens all the time.
You probably can't use the linksys program to install the software on a Windows 2000 machine you should be able to install just the driver you need. I have never used wireless networking on a Win 2000 computer before. Win XP has sotware already built into the operating systems to deal with wireless networking.
Uninstall all Linksys wireless networking software. Restart you computer with the wirless network card install and let Windows search for the correct drivers on the CD.
Jun 22, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys WMP300N Endless Bootup Loop
Disable or uninstall the Linksys software that manages and monitors the connection.
Use instead the Microsoft Windows Wireless configuration utility.
That's what I did and didn't get problem after.
Dec 30, 2007 | Linksys WMP300N Pre-802.11n Wireless...
Linksys Wireless-G WRT54G Router Logo
131 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
