Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice won,t dispence
Whirlpool side by side. push pad but no ice . ice shoot is full
  • Anonymous Nov 28, 2008
    Same problem- seems like the flap that opens to let ice out of shoot is not getting the signal to open. Very frustrating!
  • Anonymous Mar 22, 2014
    ice dispencer freezes up and will not turn, grind or dispence ice
    Sergeant:
    Champion:
  • 311 Answers
Is auger motor running? Is fork on auger motor tight or does it spin freely?
Posted on Nov 28, 2008
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Ice maker is not working. I have checked all the normal trouble shooting suggestions and it has not responded. Any suggestions?
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 20, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The ice dispencer keeps backing up and I can't get the ice bucket to come off the freezer door. Help please!!!
must be a whirlpool / or ka . open the door and let it thaw then remove it and de ice it with hot water . dry ir good and the ice delivery shoot .. spray the dry surfaces wth food grade silcone and this will helt for a while . do this about every 3 mo to prevent this prob . mm
Oct 13, 2010 | Maytag MZD2766GES Side by Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
The ice dispencer is always running out of ice there is a setting for making extra ice for hot day but lost my manual
To increase ice production for special occasions, such as parties, push the Touch Pad _ for
3-5 seconds to activate this feature. A green light will appear above the Touch Pad. Push the
Touch Pad _ again for 3-5 seconds to deactivate.
Here is a link to your manual. http://www.managemylife.com/mmh/owner_manuals/4709/FRIGIDAIRE-Side-by-Side-Refrigerator-L0302088?brand_name_search=GLRS237ZAW7+FRIGIDAIRE
Jul 08, 2010 | Frigidaire GLRS237ZA Side by Side...
Ice is frozen in the chute of my on door ice maker. I cannot remove the unit from the door because of this
Very carefully push the button on the side and pull and wiggle hard. Ice may go flying everywhere you will have to clean up the mess and then rotate and clean out the chute rotate the clamp and empty the ice container. You may need to run water through the shoot make sure you dry it before replacing the unit.
Jun 15, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice comes out when pad is depressed.
does your auger turn? thats what pushes the ice doun the shoot. if not replace the auger
Oct 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water line hooked up makes ice but no water from dispenser
Have a look at the back of the fridge. There are 2 valves that feed the ice maker and the water dispenser. Have someone push the dispenser button while you feel which solonoid activates.Once located,remove that single pipe from that valve and reactivate the dispencer button. If water shoots out then you know the problem is further on. I would suspect there is then an issue with the water filter. Remove it and inspect for defects. If the filter is old, suggest you replace it as they clog up reasonably quickly. Retry. Please let me know.
Oct 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Door inside the ice dispencer sticks open. have to push it close
Sounds like the clear plastic door guide on the ice dispensor arm , is broken loose , holding the door , keeping it from closing . If this is the problem , it just snaps on . If a piece is broken from the guide , pt # 985866 is usually the part .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
184 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
